1) I have a plane that is parallel to "Z" axis. I call this my "Top plane".
2) In the center of this plane is a 2" diameter which I measure and translate my "X" and "Y" origin. I call this Alignment-1
3) Slightly off center of the 2" dia is a .250 dia hole at 15 degrees. The projected hole should be on common centerline to the 2" diameter as it passes through my "Top plane".
4) I rotate my alignment 15 degrees, measure the .250 hole with my probe at 14, 0.
5) I CONSTRUCT, CIRCLE, PROJECT by choosing my .250 first, then my "Top plane".
6) I then recall Alignment-1 and expect to see my Projected .250 circle at center of my 2" diameter. HOWEVER, the circle is not projected by 15 degree therefore showing off centerline.
Please tell me how I may force the Constructed Circle to project at 15 degree nominal so it will report on centerline. It is projecting perpendicular to my measured plane even though I have my alignment on 15 degree.
Thank you in advance.
