Nothing major, just an irritation. Running V4.0 on B&S Global Image 555. Whenever fly mode is on the machine sometimes will take double hits when inspecting small holes. Anyone else having this problem?
t.
Global Image 555
PH10M-TP200
PC-DMIS Cad ++
Win7 64 bit
V2014.1
I have encountered this problem before also when measuring really small features using a 0.5mm diameter tip. I think it was the very small prehit / retract values I had to use and like you it irritated me, ended up moving the job onto a different machine and continuous scanning
This a known bug that started back in the 3.7 release. I had Tech support looking at this for quite sometime and they have never gotten back to me with a fix. I reported this to B&S at least a year ago if not longer.
You say your running 4.0. Everything ever said is 4.0 is crap. You might want to upgrade to a newer version. Might help ?????
Actually 4.0 has been pretty reliable. TP is still pretty strange though - still a tough thing to trust. I have 4.1 also but it doesn't always print or save the PDF after running each part and that's a bug I couldn't live with. 3.5MR2 is probably still the most solid release but if you work a lot with auto features on CAD data you can appreciate the enhancements made on the newer releases. Anyway I'm getting off topic - sounds like the double hit thing is something I'm going to live with too. I am checking over 200 holes and I like having fly mode on for travelling in and out of each hole.
Thanks to all !!!
Cheers!
t.
Global Image 555
PH10M-TP200
PC-DMIS Cad ++
Win7 64 bit
V2014.1
You are right on this one. V4.1 as originally released in August 2006, does NOT print automatically. This is a bug repaired in any newer version of V4.1 and V4.2.
Also, TP does never print IF you change your Report template. This too is a bug that hopefully will be addressed in V4.2.
I also used V4.0 for quite some time after V4.1 was out. But due to another bug in V4.0, I had to go to V4.1. It resolved many small issues, but also introduced a bunch of other ones, mostly in the reporting, specifically reporting of TP.
Anyway, I have been promised a lot of improvement in this area for V4.2. We'll see....
Jan.
Jan.
Jan,
That is valuable information... I'm going to go looking for a later release of 4.1 now. I've been struggling for months with the reporting issue and I am getting sick of having to manually print each report on every other part. Thank you!
Bob
PCDMIS 2012
Windows Office XP
Any idea when 4.2 is supposed to be released? I think I'm about ready for some more torture (hopefully my boss will be prepared for some more too). . . LOA
PCDMIS 2012
Windows Office XP
Jan.
I just downloaded 4.1Beta and my reporting problems have finally been resolved. Thanks Jan!
PCDMIS 2012
Windows Office XP
I have a part on the table it is like a cylinder and it is about .25 thick. Now there are holes that go through the cylinder wall that are threaded. i...
Every small hole diameter I measure no matter how many or how few touches I use, the holes are oversized. .003 to .004 inch. .063 will measure .067 or...
