Does anyone know if you can set snap points to the on position as a default in v4.1?
Snap Point
by inspector212I had some odd deviations of a few points in a program. The points were reporting "T" values. Two points within 10mm of each other were reporting...
10-23-2007, 12:30 PM -
by ricfreHas anyone experienced creating a program in 4.1 or sooner that when you bring it up in 4.2 and run it, if it will run, that it gives you bad true positions...
02-20-2008, 01:11 PM -
by AuRulesHit the F1 button and read the info on snap points kinda have a idea, but someone give a example or a better definition of, does it work best with sheetmetal...
04-10-2007, 10:34 AM -
Well, I would post this in the TIPS & DESCRIPTIONS section, but there isn't one (yet?). I have put this here in the CODE section since it will not...
Channel: PC-DMIS Code Samples
10-16-2006, 08:43 AM -
does anybody know if it is possible to default snap point to no in version 3.7. we are using a manual machine and need it turned off permanently
05-31-2006, 11:47 AM -
