Done Button Not Excepting Touch
  • Done Button Not Excepting Touch
    We can not get our Done button to work on our jog box. Where is the command to turn this on? Ver 3.5mr2 sharpe 32 controller.
    PCDMIS 4.1, 3.5mr2,
    Look in EDIT ~ PREF ~ CMM INTERFACE SETUP
      I believe that is the area that selects what the print button does, I would like for the done button to be set so that when I press it, it takes my hits and continues on to the next command. I can set it up so that print accepts this also, but I have that set to place move points into my programs when programming. Maybe I just over looked it, but I just couldn't find it there.
      PCDMIS 4.1, 3.5mr2,
        Well, maybe I should read the post a little better. I was thinking PRINT, not DONE. Hit F5, it will be in the scroll-down list that is on the first tab. You can either set it to 'done' a feature or to disable it, those are the only options.
          Vondy, I too have a 9-15-9 Excell with a Sharpe 32 controller. Sometimes for reasons partially unknown the done and print buttons will stop working on my jogbox. My theory is that for whatever reason the controller stops recognizing the signal from the jogbox. Closing down and shutting off the controller has always fixed the problem. Fortunately it does not occur very often. It happens sometimes after the tip fouls out, especially if it happens twice in a row. Other times there is no apparent cause. HTH
            What Matt and Wes says...
            There's also EDIT - PREFERENCES - SETUP - GENERAL TAB look for "Press End Key" select by placing check mark...
            PC-DMIS CAD++ 3.7 from 4.2 MR1
              We have that happen also.... just quits functioning.
              Our solution: reboot computer AND controller once each day.
              Lately, it occurs to me
              2017 R1 (Offline programming)
                Just try shutting everything down and reboot that has worked for me in the past when that has happened
                Tolerance challenged ... Living in the world of unseen lines.
                • gishak
                  Move point with the print button on the jog box.
                  by gishak
                  Help i used to be able to insert move point using the print button on the jog box now after upgrading to windows 7 this button do not work. is there a...
                  03-21-2014, 02:43 PM
                • 56flh
                  Jog box "print" button
                  by 56flh
                  I may be overlooking something obvious, but it seems I've lost the ability to insert a move-point into a program by pressing the "print" button...
                  07-19-2006, 11:38 AM
                • Farmer
                  Jog Box
                  by Farmer
                  Hi, Im fairly new to Dmis. I have only completed the basic training, so apologies if this is a silly question. Is it possible to re-programme the jog...
                  06-29-2006, 04:08 AM
                • bigjosh
                  programming jog box
                  by bigjosh
                  I have the "normal" B&S jog box and want to program the print and done buttons . I have the print button set up to insert move points ,...
                  06-19-2012, 10:20 AM
                • LASARD
                  Cmm Controller
                  by LASARD
                  Hello Out There. Wondering If Anyone Can Help Me. I Am Running Pc Dmis V3.7 Using A Dea Tu01 Controller.
                  I Was Wondering If There Was...
                  05-30-2007, 11:38 AM
