We check the draft of cored holes in castings all the time, not to mention the corresponding feature on the steel. We use cones, then dimension the angle of the cone. The angle will give you the total angle, so you need to divide the angle by 2 and assign to a generic feature, otherwise, you can just dimension the total angle.
How would I determine an inclusive angle? I am measuring a cone with a very minimal plane at the top of the part. (Maybe .002 land) 100 deg +/- 1 deg...
we have a product like a Fin(image attach) it has 10 wings and on each wing there is 1 degree angle to the centre line.I make plane on every wing and...
