Hey all
I was wondering if I am doing True postion right
I am doing the TP of a Hub my 1st and 2nd datums are a plane and another ID
I pick the Hub 1st then the plane and last the other ID the feature control frame has a MMC in the callout for the true postion as well as the other ID. My answer cam out greem but am just wondering if mythinking is correct?
DATUMA =FEAT/PLANE,RECT,TRIANGLE
THEO/-5.344,1.427,-0.774,-0.0024347,-0.0048803,0.9999851
ACTL/-5.349,1.417,0.396,0.0000352,-0.0000655,1
MEAS/PLANE,4
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,9.693,-4.535,-0.743,-0.0024347,-0.0048803,0.9999851,9.687,-4.545,0.395,USE THEO = YES
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,9.66,8.163,-0.728,-0.0024347,-0.0048803,0.9999851,9.654,8.153,0.396,USE THEO = YES
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-20.383,8.081,-0.757,-0.0024347,-0.0048803,0.9999851,-20.387,8.071,0.397,USE THEO = YES
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-20.347,-6,-0.868,-0.0024347,-0.0048803,0.9999851,-20.351,-6.01,0.396,USE THEO = YES
ENDMEAS/
BOTHUB =FEAT/CIRCLE,RECT,OUT,LEAST_SQR
THEO/-13.08,-0.032,11.406,0,0,1,3.736
ACTL/-13.063,0.005,11.408,0,0,1,4.035
MEAS/CIRCLE,4,WORKPLANE
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-14.791,-0.478,11.404,-0.9675808,-0.2525615,0,-15.007,-0.525,11.405,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-13.215,1.914,11.406,-0.0695455,0.9975788,0,-13.217,2.018,11.406,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-11.335,-0.283,11.408,0.9897422,-0.1428652,0,-11.071,-0.31,11.413,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-12.854,-2.009,11.406,0.1135116,-0.9935367,0,-12.847,-2.003,11.407,USE THEO = YES
ENDMEAS/
TOPHUB =FEAT/CIRCLE,RECT,OUT,LEAST_SQR
THEO/-13.192,-0.05,13.826,0,0,1,3.562
ACTL/-13.061,0.001,13.83,0,0,1,4.024
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-14.971,-0.359,13.825,-0.985207,-0.1713688,0,-15.039,-0.363,13.829,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-13.112,1.707,13.826,0.0455712,0.9989611,0,-13.054,2.014,13.828,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-11.396,-0.259,13.828,0.9933112,-0.1154684,0,-11.069,-0.275,13.834,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-13.133,-1.8,13.827,0.0337217,-0.9994313,0,-13.081,-2.012,13.828,USE THEO = YES
ENDMEAS/
BOTID =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/-0.045,-0.074,1.632,0,0,1,4.423
ACTL/0.008,-0.012,1.631,0,0,1,4.239
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,0.081,2.143,1.632,-0.0567651,-0.9983876,0,0.031,2.11,1.634,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,0.092,-2.29,1.632,-0.0619194,0.9980812,0,0.026,-2.135,1.633,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,2.157,-0.057,1.632,-0.9999711,-0.0076044,0,2.122,-0.112,1.632,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-2.248,-0.071,1.631,0.999999,-0.0013942,0,-2.106,-0.125,1.628,USE THEO = YES
ENDMEAS/
TOPID =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/-0.07,-0.085,8.291,0,0,1,4.454
ACTL/-0.013,-0.008,8.294,0,0,1,4.226
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-2.287,-0.061,8.291,0.999944,-0.0105868,0,-2.13,-0.13,8.297,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,2.146,-0.048,8.292,-0.9998592,-0.0167823,0,2.104,-0.115,8.296,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-0.048,2.152,8.29,-0.0099095,-0.9999509,0,-0.101,2.097,8.293,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,-0.037,-2.321,8.291,-0.014998,0.9998875,0,-0.099,-2.113,8.291,USE THEO = YES
ENDMEAS/
CYLHUB =FEAT/CYLINDER,RECT,OUT,LEAST_SQR
THEO/-13.136,-0.042,12.617,-0.0455563,-0.0010119,0.9989613,3.647,2.58
ACTL/-13.062,0.003,12.62,0.0006927,-0.0013164,0.9999989,4.03,2.432
CONSTR/CYLINDER,BF,BOTHUB,TOPHUB,,
CYLID =FEAT/CYLINDER,RECT,OUT,LEAST_SQR
THEO/-0.058,-0.079,4.961,-0.0037114,-0.0015998,0.9999918,4.438,6.675
ACTL/-0.003,-0.01,4.964,-0.0030692,0.0006253,0.9999951,4.233,6.678
CONSTR/CYLINDER,BF,BOTID,TOPID,,
DIM ITEM21= 2D DISTANCE FROM CYLINDER CYLHUB TO CYLINDER CYLID (CENTER TO CENTER), NO_RADIUS UNITS=MM ,$
AX NOMINAL +TOL -TOL MEAS MAX MIN DEV OUTTOL
M 13.000 0.250 0.250 13.059 13.059 13.059 0.059 0.000 -----#---
DIM PERP2= PERPENDICULARITY OF CYLINDER CYLHUB,RFS TO PLANE DATUMA,RFS EXTENDLENGTH=0.000 UNITS=MM ,$
M 0.000 0.100 0.000 0.003 0.002 0.002 0.003 0.000 #--------
DIM ITEM19= PERPENDICULARITY OF CYLINDER CYLID,MMC TO PLANE DATUMA,RFS EXTENDLENGTH=0.000 UNITS=MM ,$
AX NOMINAL +TOL -TOL BONUS MEAS MAX MIN DEV OUTTOL
DF 0.000 0.000 0.000 0.000 0.000 0.000 0.000 ----#----
M 0.000 0.200 0.000 0.000 0.021 0.011 0.011 0.021 0.000 #--------
DIM ITEM24= TRUE POSITION OF CYLINDER CYLHUB USE AXIS=AVERAGE REF LENGTH=0.000 UNITS=MM ,$
GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER
AX NOMINAL +TOL -TOL BONUS MEAS DEV DEVANG OUTTOL
X -13.136 -13.074 0.063
Y -0.042 -0.028 0.014
DF 4.000 0.050 0.050 0.020 4.030 0.030 0.000 -------#-
D1 PLANE DATUMA AT RFS
D2 4.200 0.100 0.000 0.045 4.245 CIRCLE DATUMB AT MMC
TP MMC 0.200 0.020 0.128 12.580 0.000 -----#---
END OF DIMENSION ITEM24
MEAS/PLANE,4
MOVE/CLEARPLANE
MOVE/CLEARPLANE
MOVE/CLEARPLANE
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
ENDMEAS/
MOVE/CLEARPLANE
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
ENDMEAS/
MOVE/CLEARPLANE
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
ENDMEAS/
MOVE/CLEARPLANE
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
ENDMEAS/
