I can get around this by re-booting, and it's only happened twice in the past year or so. I'm just curious as to whether anyone else has experienced it and would like to know if anyone has any ideas as to why it may happen. I saved the program I was working on in V3.7 MR2 (XP SP2). I tried to close, it would not, got no error, just remained open. I tried to quit, it would not. I hit X in upper right hand of window. It closed. This morning I come in, open PC D-MIS and it comes up fast with the file I had been working on yesterday, already open. I close and check the task manager to see if somehow PC D-MIS is running in the background, I find it is not. I open PC D-MIS again, it opens again with the file already loaded. I reboot the system. Problem solved.
Can't close or quit
Mine used to do this. It no longer does. I'm not sure if the hotfix for SP2 fixed it or downloading and installing MR3 fixed it. I would suggest doing both anyway.
If you open pc-dmis and the file opens itself, do a ctrl+alt+del. Then go to the task manager, highlight pc-dmis and choose "end task". That saves you the re-boot.Last edited by #2#; 01-19-2007, 09:20 AM.
I have had this too. I thought all my PC-DMIS processes were closed, but low and behold, one was still lurking. I do not know why. PC-DMIS sometimes spawnes a few sessions? No idea, but one is still out there, eventhough you thought all was closed.
Agree with Goodluck: kill them using taks manager. That's the quickest.
I just had this happen yesterday. PCDMIS problems seem to happen around the same time collectively.
All part of the SMA conspiracy I tell ya!I used to be high on life but I built up a tolerance.
Originally posted by Underspec View PostI just had this happen yesterday. PCDMIS problems seem to happen around the same time collectively.
Forgot to mention I also use 3.7MR3I used to be high on life but I built up a tolerance.
Originally posted by Underspec View PostForgot to mention I also use 3.7MR3Originally posted by Bill McCafferty View PostI had it happen the other day ONE time only with 3.7 Mr3 so that's not the fix either.Originally posted by Greg Haglin View PostClick on the print preview button - then close the print preview page - This seems to work for a few 'lockups' I've had.
3.7 mr3
by williamHas anyone ever seen this before and have any idea what causes it/how to fix it? This is what I found when I open a program that someone else copied and...
05-12-2015, 11:55 PM -
by BANDYOk, I was about to finish programing this F-35 part when Dims crashed and everytime I try to open Prg it crashes again. PCDLRN has encountered a problem...
09-14-2006, 09:09 PM -
by lcrowstonI have been out for a couple weeks, started my old DEA, opened PC DMIS, machined homed fine, when I go to open a file my usual file folder that has all...
08-05-2019, 02:12 PM -
by AA/AlteredDoes anyone have experiance using Open DMIS? I saw a job and applied for it but do not know Open DMIS software. If it is similar & it would be like...
09-30-2010, 01:48 PM -
I am using PC DMIS V4.1. I was running my program and PC DMIS shut down. I went to open it back up and got a "Serialization error: ALT", and...
02-28-2007, 06:32 PM -
