Auto plane square vs radial
  • Auto plane square vs radial
    Has anyone ever gone into autoplane and changed
    from square to radial or vise versa.
    Then closed that program opened a different program to run
    and found that the autoplane has been changed also ???
    No
    but i would like to know the difference too
      well the difference is a program that used to run fine
      then you save it start another program and change the methode of autoplane.
      save that program.
      then open the program that used to run fine and find out its autoplane
      has also changed and wont run now
        I was thinking when creating a plane
        that this was a setting
        i mis read the question
        still got 2 more post's to my name!
        whos going to hit 500 first
        another poll ?
          I've used auto planes before in radial checking the bottom of a can for flatness. Took like 100 hits but anway, I have not seen any bug like that on my version (MR1). I bet it's a bug. I do know that when you F9 a feature and change it, the next time you go and start the same kind of feature, the settings stay the same as last time.
          Not sure what version you using but probably another bug to add to the pile.
          • CarfinBear72
            Auto Plane
            by CarfinBear72
            Looking for a bit of help,
            Trying to use the auto plane function for the first time. I'm taking a plane on a thin ring, so want to be able...
            08-08-2017, 10:19 AM
          • Bearded_buddah
            pc-dmis cmm autosave?
            by Bearded_buddah
            The situation - I keep coming into work to find out that part of a program "mysteriously" changed (ie work plane got changed from z+ to y- in...
            01-29-2016, 01:21 AM
          • AuRules
            Planes
            by AuRules
            A question for all of the sick individuals (which is a good thing) from the other thread, running 3.7mr2 today and usually when I use a plane on my round...
            05-10-2007, 10:29 AM
          • DungT
            Coruppted Autoplane
            by DungT
            Weird thing just happened. Everything’s going well until # “4” key on my keyboard got stuck while trying to key in the nominal in auto plane window....
            08-25-2011, 05:22 PM
          • jleond
            auto plane bug-3.7mr3?
            by jleond
            When I measure an auto plane with actual thickness selected (2mm) the actual meas is wrong, using a constructed plane from vector points (with 2mm actual...
            08-29-2008, 11:09 PM
