F9 And Startup
  • F9 And Startup
    I have a program that I needed to change how it sat on the CMM. Once I got it in to it's new position I did a F9 to move some hit points that could nolonger be reached in this new position. "These points were my itrative alignment points". As soon as I tried to run the program I got booted completely out off PC DMIS. I reopened PC DMIS and attemped to reopen my part program. At 85% thru it loading the program fails and I am booted back out of the part program and out of PC DMIS. I have tried this servial times and each time with the same results. Does anyone know of a way around this. I screwed-up and did not save a backup of the old part program. I am running v4.1. I am not getting any error codes so I don't really know where to go from here.
    This may or may not help. Try shuting machine completly down & repower back up.
      I hate to say but I think your screwed
        Yeah I tried that too. no luck yet.
        Thanks thou.
          Now thats not the answer I was looking for at all.
            Thanks thou.
            Which one did you try. The power down or getting screwed. Sorry could not resist. Hope you get it fixed....
              Just a thought, try to open it "offline"?
                If it has a CAD file associated with it you could try renaming that before opening it to.
                Mr. Comment
                SCIROCCO-NT 13-20-10
                  That is one reason I mark all my programs "read only" after I finish them. Then, if I need to modify one, I can't save it without giving it a new name = I have a backup for when I screw up the modified one.
                  I have no suggestions for solving the problem. I guess I would try opening another program to make sure you can at least get one open (program problem or pcdmis problem?) Then maybe try opening it offline like James suggested???
                    No, no luck opening it offline.
                    Thanks for all the suggestion thou. Looks like I'll just have to take it as a reminder that if I not going to make sure I have a back-up I don't care enough about the program and I can just remake it.
                      Send me the program. I'll see if I can open it?
                      [email protected]
                        Did you try deleting the PROBE FILE it is calling for?
                          Good answer Matt that might do it.
