Is there a way to output the hit points in textual analysis thru Datapage or the pcdmis-excel dump? I can get them to show up in the rtf but a customer wants to input those hits into their software. Using 3.7 MR3 on a Mistral 7-7-5 and a Wenzel 6-7-5.
textual analysis
You use the location dimension and alittle looping to report out each hits value to datapage.
Code:STARTUP =ALIGNMENT/START,RECALL:,LIST=YES ALIGNMENT/END MODE/DCC FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,DEV,OUTTOL, , LOADPROBE/20X4X20 TIP/T1A90B-90, SHANKIJK=1, 0, 0, ANGLE=-90 STATS/ON,DATAPAGE,$ DIRECTORY=D:\DP\MYGREATESTHITS1,$ DIRECTORY=,$ READ=10,WRITE=20,MEMPAGES=64,DIMENSION NAME,CONTROLCALC OFF,$ STATS/END CIR1 =AUTO/CIRCLE,SHOWALLPARAMS = YES,SHOWHITS = YES THEO/0,0,17.5,0,0,1,11,0 ACTL/0,0,17.5,0,0,1,11,0 TARG/0,0,17.5,0,0,1 THEO_THICKNESS = 0,RECT,OUT,CIRCULAR,LEAST_SQR,ONERROR = NO,$ AUTO MOVE = NO,DISTANCE = 15,RMEAS = None,None,None,$ READ POS = NO,FIND HOLE = DISABLED,REMEASURE = NO,$ NUMHITS = 20,INIT = 0,PERM = 0,SPACER = 4,PITCH = 0,$ START ANG = 0,END ANG = 360,DEPTH = 0,$ VOID DETECT = NO,$ ANGLE VEC = 1,0,0 MEAS/CIRCLE HIT/BASIC,5.5,0,17.5,1,0,0,5.5,0,17.5 HIT/BASIC,5.231,1.7,17.5,0.9510565,0.309017,0,5.231,1.7,17.5 HIT/BASIC,4.45,3.233,17.5,0.809017,0.5877853,0,4.45,3.233,17.5 HIT/BASIC,3.233,4.45,17.5,0.5877853,0.809017,0,3.233,4.45,17.5 HIT/BASIC,1.7,5.231,17.5,0.309017,0.9510565,0,1.7,5.231,17.5 HIT/BASIC,0,5.5,17.5,0,1,0,0,5.5,17.5 HIT/BASIC,-1.7,5.231,17.5,-0.309017,0.9510565,0,-1.7,5.231,17.5 HIT/BASIC,-3.233,4.45,17.5,-0.5877853,0.809017,0,-3.233,4.45,17.5 HIT/BASIC,-4.45,3.233,17.5,-0.809017,0.5877853,0,-4.45,3.233,17.5 HIT/BASIC,-5.231,1.7,17.5,-0.9510565,0.309017,0,-5.231,1.7,17.5 HIT/BASIC,-5.5,0,17.5,-1,0,0,-5.5,0,17.5 HIT/BASIC,-5.231,-1.7,17.5,-0.9510565,-0.309017,0,-5.231,-1.7,17.5 HIT/BASIC,-4.45,-3.233,17.5,-0.809017,-0.5877853,0,-4.45,-3.233,17.5 HIT/BASIC,-3.233,-4.45,17.5,-0.5877853,-0.809017,0,-3.233,-4.45,17.5 HIT/BASIC,-1.7,-5.231,17.5,-0.309017,-0.9510565,0,-1.7,-5.231,17.5 HIT/BASIC,0,-5.5,17.5,0,-1,0,0,-5.5,17.5 HIT/BASIC,1.7,-5.231,17.5,0.309017,-0.9510565,0,1.7,-5.231,17.5 HIT/BASIC,3.233,-4.45,17.5,0.5877853,-0.809017,0,3.233,-4.45,17.5 HIT/BASIC,4.45,-3.233,17.5,0.809017,-0.5877853,0,4.45,-3.233,17.5 HIT/BASIC,5.231,-1.7,17.5,0.9510565,-0.309017,0,5.231,-1.7,17.5 ENDMEAS/ V1 =LOOP/START, ID = YES, NUMBER = CIR1.NUMHITS, START = 1, SKIP = , OFFSET: XAXIS = 0, YAXIS = 0, ZAXIS = 0, ANGLE = 0 DIM LOC1= LOCATION OF POINT CIR1.HIT[V1] UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL X 5.231 0.010 0.010 5.231 0.000 0.000 ----#---- Y -1.700 0.010 0.010 -1.700 0.000 0.000 ----#---- Z 17.500 0.010 0.010 17.500 0.000 0.000 ----#---- END OF DIMENSION LOC1 LOOP/END
Mr. Comment
SCIROCCO-NT 13-20-10
Originally posted by craiger_ny View PostNice solution. I think he might need to see the V1 declaration and the V1 = V1 + 1 after the dimension unless I am missing something.
Craig
In this case the Loop ID is my declaration for V1 and my step is also +1 for the loop. Basically this replicates code using a seperate variable and a line after the dimension where you would need put V1=V1+1.Mr. Comment
