We have an excessive amount of oil on all of the axis rails. We already have 3 filters in line and they are always dry. Any suggestions? We had some one come in to calibrate the CMM and he made the statement that “the air bearings are leaking oil". To my understanding the air bearings do not contain oil when initially installed. I can understand if they have oil build up from the incoming air but not leaking due to pre-fill. We occasionally receive a Z axis error.
MicroVal 343 Oil Problem
Originally posted by SqDqa View PostWe have an excessive amount of oil on all of the axis rails. We already have 3 filters in line and they are always dry. Any suggestions? We had some one come in to calibrate the CMM and he made the statement that “the air bearings are leaking oil". To my understanding the air bearings do not contain oil when initially installed. I can understand if they have oil build up from the incoming air but not leaking due to pre-fill. We occasionally receive a Z axis error.
No oil should be coming in through your airlines. Instead of filters, you may want to try an air dryer and/or a membrane type filter. That and get off the main airlines if you maintainance department can't stop the oil in the air lines.sigpic
Originally posted by SqDqa View PostWe have an excessive amount of oil on all of the axis rails. We already have 3 filters in line and they are always dry. Any suggestions? We had some one come in to calibrate the CMM and he made the statement that “the air bearings are leaking oil". To my understanding the air bearings do not contain oil when initially installed. I can understand if they have oil build up from the incoming air but not leaking due to pre-fill. We occasionally receive a Z axis error.PC-DMIS CAD++ 3.7 from 4.2 MR1
We had a similar problem, not long ago. Placement of the filters (away from the cmm - like 6ft) and the addition of an oil seperator - all before the CMM's air filters (these should be the LAST line of defense) cured our problem. So we have {incoming} - gravity drop, air filters, oil seperator, {6ft line - branch's to our 2 CMM's air lines...} CMM filters {CMM}.RFS Means Really Fussy Stuff
You need an air dryer AND a moisture trap in your supply lines! Immediately.
Some compressors lubricate the scrolls or pistons or whatever they use with an oil mist. EVENTHOUGH your main compressor MAY have an air dryer right at the compresssor, DO NOT trust those!!!!
Just buy a simple air dryer (10SCFM ought to be enough for you) and plumb it in right before you go into the machine. You'll see the oil and water pour out!
Also, have you maintenance crew plumb in a moisture trap. I typically do that where the air enters my room. Just plumb a "dead" piece of pipe striaght down and put a ball valve at the end. Once a day, open that ball valve. Make sure that you have a bucket under it because you'll be surprised how much junk (moslty a watery oil mixture) will blow out. Just crack the line open for a few seconds and you'll be all set.
Good luck, Jan.***************************
by BOBN1The Mistral B&s Cmm I Program Has No Air Dryer And It Has Not Had One For The 8 Months I Have Worked There. It Gets Loads Of Oil And Moisture On The...
08-31-2006, 03:20 AM -
by Eastmangood afternoon all,
my brown and sharp dcc is have a bit of oil trouble I've been maintaining it with just a bit of isopropyl
04-25-2016, 04:01 PM -
by Paul SarrachHas anyone have a Air Dryer be the cause of oil in the air lines? I have no oil coming into but have it coming out of?
Or is this just...-
07-23-2008, 12:27 PM -
I HAVE A SHEFFIELD 9.9.7 ,MY LEFT SIDE AIR BEARING IS MAKING A STAING ON THE TABLE IS THAT NORMAL?
01-11-2007, 04:21 PM -
by TRD_racingI have a Global Image 9-12-8 and I am getting my machine calibrated in a few weeks. BS wants $135 to change the inline filters. Does anyone know where...
07-29-2006, 11:02 AM -
