Constructed Cylinders
  • Constructed Cylinders
    I feel dumb today. I want to construct a cylinder from a number of circles that I have measured in a hole. I know this has been discussed here, but for some reason I can't get it to work. V3.2063, Mistral. Everytime I construct it, the software won't let me.
    BF selected?
      I've tried every option, even cast & projected knowing that would create a cylinder for each circle. It'll do that, but not give me a constructed cylinder.
        I'm using Auto-circles, could it be that??
          what are the noms for the circles?
            CIR4       =AUTO/CIRCLE, SHOWHITS=NO, SHOWALLPARAMS=YES
                        THEO/0,0,-0.114,0,0,-1,0.2259
                        ACTL/0,-0.0002,-0.114,0,0,-1,0.2266
                        TARG/0,0,-0.114,0,0,-1
                          THEO_THICKNESS = 0, RECT, IN, CIRCULAR, MAX_INSC ,$
                          AUTO MOVE = NO, DISTANCE = 0, RMEAS = None, READ POS = NO, FIND HOLE = NO, REMEASURE = NO ,$
                          NUMHITS = 9, INIT = 0, PERM = 0, SPACER = 0, PITCH = 0 ,$
                          START ANG = 0, END ANG = 360, DEPTH = 0 ,$
                          ANGLE VEC = -1,0,0
            CIR5       =AUTO/CIRCLE, SHOWHITS=NO, SHOWALLPARAMS=YES
                        THEO/0,0,-0.175,0,0,-1,0.2259
                        ACTL/0,-0.0002,-0.175,0,0,-1,0.2262
                        TARG/0,0,-0.175,0,0,-1
                          ANGLE VEC = -1,0,0
            CIR7       =AUTO/CIRCLE, SHOWHITS=NO, SHOWALLPARAMS=YES
                        THEO/0,0,-0.225,0,0,-1,0.2259
                        ACTL/0,-0.0001,-0.225,0,0,-1,0.2261
                        TARG/0,0,-0.225,0,0,-1
                          ANGLE VEC = -1,0,0
            CIR8       =AUTO/CIRCLE, SHOWHITS=NO, SHOWALLPARAMS=YES
                        THEO/0,0,-0.275,0,0,-1,0.2259
                        ACTL/0.0001,-0.0001,-0.275,0,0,-1,0.2263
                        TARG/0,0,-0.275,0,0,-1
                          ANGLE VEC = -1,0,0
            CIR9       =AUTO/CIRCLE, SHOWHITS=NO, SHOWALLPARAMS=YES
                        THEO/0,0,-0.325,0,0,-1,0.2259
                        ACTL/0.0001,0,-0.325,0,0,-1,0.2261
                        TARG/0,0,-0.325,0,0,-1
                          ANGLE VEC = -1,0,0
              I would extract the points and construct the cylinder from them
              TK
              sigpicHave a homebrew
                Wp? - or could you use a 3-d line?
                RFS Means Really Fussy Stuff
                  Not that big a deal. I was just trying to show that the hole was tapered and that the part mating this will slip in. It shouldn't.....
                  Location is non-existent, it is a gage to sort nonconforming parts.
                    Pick it up as a cone, then intersect the cone with planes at the levels you want show circle dimeters for. Dimension the circle diameters and you should be there.
                    Bill
                      Thanks Guys! Time for beer.
                        I like the cone idea if it's truly a cone. For the points method this will give you a cylinder...
                        TK
                        V1 =LOOP/START, ID = YES, NUMBER = 3, START = 1, SKIP = ,
                        OFFSET: XAXIS = 0, YAXIS = 0, ZAXIS = 0, ANGLE = 0
                        PNT1 =FEAT/POINT,RECT
                        THEO/-2.5,-4.33,-1,0.5,0.8660254,0
                        ACTL/3.103,-4.177,-637.525,0,-1,0
                        CONSTR/POINT,CAST,CIRCLE1.HIT[V1]
                        PNT4 =FEAT/POINT,RECT
                        THEO/-2.5,-4.33,2,0.5,0.8660254,0
                        ACTL/-4.667,1.918,-632.687,-1,0,0
                        CONSTR/POINT,CAST,CIRCLE4.HIT[V1]
                        LOOP/END
                        CYL1 =FEAT/CYLINDER,RECT,IN,LEAST_SQR
                        THEO/-2.5,-2.513,8.817,0,0,1,10,8.66
                        ACTL/0.008,0.008,-634.986,0.0565378,0.0307684,0.9979262,10.332,5.238
                        CONSTR/CYLINDER,BF,PNT1[1],PNT1[2],PNT1[3],PNT4[1],PNT4[2],PNT4[3],,
                          So, what did you do>?
                            Well, he did say it was time for a beer, Mmmmm, beer...
                            TK
                              John,
                              The bore does not look like it's taper from the measured results - more like waves or coke bottle...
                              Try constructing immediately after circle measurements and did you choose IN or OUT when constructing the cylinder?
                              Brewski sounds good maybe I'll have one for lunch...ZZZZZ
                              PC-DMIS CAD++ 3.7 from 4.2 MR1
