My Dea Controller just shows red light flashing under question mark when i turn key. Machine acts like is stop is set although both e-stops are disengaged (jog box and controller). Any help?
Dea Tutor P connected to Beta Sp CMM
Try this
1) Are you pushing the motor start button. On my controller this is the green push button next to the E stop button on the controller.
2) Some time ago, I was having the same problem. When I would start up, the red led would go out, then a few seconds later come back on. It would come and go, sometimes just resetting the controller would fix it. I ended up finding a loose connection in the jog box. There are two places to check; both are plug in strips. The first is on the E stop button-that one seems to be prone to wiggle loose. The other is where the cable hooks to the board in the jog box. If you jog box made a trip to the floor recently, I'd bet one of these may have come loose.Last edited by Rick Coleman; 01-13-2007, 10:39 AM.sigpic:eek: Bring out the comfy chair!:eek:
Once I had same kind problem. X5 connector were not connected well. Try to check this connector / we found there was a space between the connector and the pins.If so , remove (cut) the connector and weld the cables directly to the pins. You may find this connector inside the controller , behind the transformator , right hand side-back.
Another things to be checked ,
* All cable connections behind the controller
* Emergency leds -inside the controller , there is a emergency board, near the transformator , you may check its leds according to the scheme. (+/- Voltages,air supply etc etc)
HTH
Maqsigpic
by roselyJust after Hexagon calibration, the controller now lags in response to being moved by hand. This is the electronic controller. Isn't there a way to...
03-08-2013, 11:12 AM -
by CJonesOur machine has been down for a few days, and here's is what I know. It's an Excel 7-10-7 with a PH9A and TP2 running 3.5. One of the engineers was in...
07-26-2010, 11:37 AM -
by rtlawlorSo one of our machines, BROWN & SHARPE CMM ( DCC TOUCH PROBE ) GLOBAL IMAGE 7107. I'm having problems with the JOGGER BOX not turning on.
09-26-2016, 05:00 PM -
by kama2818I got this problem the machine not moveing and the software not running too.
09-06-2018, 03:28 PM -
by CumofoWe all know the routine: "probe unseated...", or you're moving the machine to a read point and it begins to accumulate false hits in the buffer:...
01-17-2020, 12:53 AM -
