I have a cylindrical part with a 4" bolt circle on one end with the 3, 10-32 tapped holes located at 30, 150 and 270 degrees. The way this is dimensioned, the 30 and 150 degree holes are located at a specific dimension from the centerline of the cylinder with a tolerance of +/- .0005, and then the bolt circle has a +/- .0005 tolerance.
I aligned with this end geometry in Y- with the 30 and 150 holes rotated to X+, and then measured the distance from the center to the two tapped holes relative to the Z axis and also reported polar radius to see if, should the bolt circle be out of spec, if I could get a better idea of location of the tapped holes. I found the distance from center to two tapped holes both off by .001+ and the bolt circle to be under by .0015. The person I was measuring this for said they didn't trust the CMM and proceded to manually measure getting slightly different results.
Is the CMM capable of these small tolerances and is there a better way I could approach this.
