Greetings,
When measuring a vertical hole that comes through an angled surface. Using CAD data and auto circle. When I select the hole on the cad it places the circle hits on the same plane as the surface. The problem is, the nominals (X&Y) are not correct. (because it is an egg shaped hole when looked at from the angle)If I change the normal vector to 0,0,1 and move the hits down into the hole using the depth feature I can measure the hole OK but the nominals are still incorrect. The only way I have found to get the correct nominals is to pick my hits down in the hole at the next lower wire frame line and then move them up in the hole to measure. However, that is not always possible.
Does anyone know of another way to do what I want with PCDMIS?
Using Ver. 3.7 mr3
Any and all input is appreciated!
Thank You,
John
Using Ver. 3.7 mr3
Thank You,
John
