How do I hide the probe head (PH9) in grafics window. I just want to see the tip only
Hide the probe head in grafics
Sometimes even the tip becomes more than you want to see. You can make it transparent EDIT/ Graphics Display window/ Lighting , Materials . Click on Lighting button/ PROBE/ click on Transparncy and this will open a slider button that you can adjust so you can see through the tip but still see where the tip is. IT is sort of a ghost image.Tolerance challenged ... Living in the world of unseen lines.
Originally posted by Lee Johnson View PostSometimes even the tip becomes more than you want to see. You can make it transparent EDIT/ Graphics Display window/ Lighting , Materials . Click on Lighting button/ PROBE/ click on Transparncy and this will open a slider button that you can adjust so you can see through the tip but still see where the tip is. IT is sort of a ghost image.
by PCFreddieIs it requred to qualify the tip everytime I turn on the machine or change to a new tip? If it is not calibrating the tip then maybe no need to do it...
01-11-2011, 05:27 PM -
by garnerjI have another question. I have a probe, 5 way exten, Tip #1 is 6X75MM, Tip#2 4X40, Empty connection #3, Tip#4 4X40, and empty connection in 5
06-13-2013, 09:45 AM -
by cesarhartI have a question regarding the probe tip rotation,in order for me to change the rotation of the probe tip I have to press CTRL E after I have chosen...
08-06-2008, 06:50 PM -
by BKBANKSis it posable to replace just the 'ruby tip' portion of the probe, rather than replacing the hole probe?
kind regards
B...-
Channel: PC-DMIS Portable
08-20-2008, 01:04 PM -
Hi,
I have been running my parts program to inspect parts for years. Last week, when the machine was on, i removed Probe Module from Probe...-
06-12-2012, 12:01 PM -
