Air Bearings
  • Air Bearings
    I HAVE A SHEFFIELD 9.9.7 ,MY LEFT SIDE AIR BEARING IS MAKING A STAING ON THE TABLE IS THAT NORMAL?
    Do you have a combination air dryer and air filter on your air lines?
    You may have water/oil coming through your air lines.
    ZydecoPete
      What's your table material? I presume granite?
      A stain is not really abnormal.
      HOWEVER, it can also be an indication that you have too much liquids in your air lines (can be water, but also some compressors leave an oil mist in the air). Do you have an air dryer hooked up? Do you keep the filters clean? Do you have a liquids trap on the incoming air line and do you clean it out regularly?
      If you do all that, it is probably harmless. Make it a point to either turn off the air before you go home, or park the machine in a different location every night. That will make sure the stain won't get any worse.
      Jan.
        I would say... If you let it sit in an unstained area and the area becomes stained that you have water or oil in your air. If the stain goes away it is probably water. If it seems to stay, probably oil. I would think that you would see it in all the bearings eventually. I would make sure you have adequate filtration and drying at any rate. The cost of those is good insurance against future more expensive problems.
          Is it a black streak or an overall stain the size of the airbearing?
            yes. I had water on my line
              Thanks Bud
                Ask to have a large clear water trap put in the Air Line. Put it in a visable location. So you can see the condesation build up before there is trouble.
                Moisture is not a CMM's friend
                Tolerance challenged ... Living in the world of unseen lines.
                • Paul Sarrach
                  Air Dryer Problems ( Oil )
                  by Paul Sarrach
                  Has anyone have a Air Dryer be the cause of oil in the air lines? I have no oil coming into but have it coming out of?
                  Or is this just...
                  07-23-2008, 12:27 PM
                • BOBN1
                  No Air Dryer
                  by BOBN1
                  The Mistral B&s Cmm I Program Has No Air Dryer And It Has Not Had One For The 8 Months I Have Worked There. It Gets Loads Of Oil And Moisture On The...
                  08-31-2006, 03:20 AM
                • biohazard
                  Air regulator and dryers
                  by biohazard
                  I got a 2 bowl air pressure regulator and the second bowl is about half way full of oil. I'm guessing it is catching the oil from shop air and removing...
                  10-28-2013, 05:14 PM
                • Eastman
                  air bearings
                  by Eastman
                  good afternoon all,
                  my brown and sharp dcc is have a bit of oil trouble I've been maintaining it with just a bit of isopropyl
                  04-25-2016, 04:01 PM
                • miles.c
                  Air Drye
                  by miles.c
                  Greeting ladies and gentlemen, I have a pretty substantial problem. I need to know how to drain the oil from the air dryers/ air filters.
                  03-30-2018, 12:36 AM
