Report template
  • Report template
    I'am using version 4.1, I want to modify the existing rules, for the circularity:
    If you select textual analyze in report the measuring points are displayed, this is manage by this command IF "TOGGLEVALUE(TEXT_ANALYSIS)>0" then USE TEMPLATE "textualanalysis.lbl"
    I Want to create a similar command when graphical analysis is selected, but I don't know the TOGGLEVALUE for this checkbox...
    IF "TOGGLEVALUE(???????????)>0" then USE TEMPLATE "graphicalanalysis.lbl"
    Thank's a lot...
    Jpc-Dmis
    works for me
    As you might have guessed, its just - "GRAPH_ANALYSIS" as in
    if "TOGGLEVALUE(GRAPH_ANALYSIS)>0" Then xxxxxxxxxxxx
    I tried it, works fine, I just used a text expression to test it with.
