I am measuring a cylinder in autofeatures. 3 rows, 6 hits per row. How can I dimension the diameter of the cylinder at the three heights it is being measured at? Make sense?
STARTUP =ALIGNMENT/START,RECALL:,LIST=YES ALIGNMENT/END MODE/MANUAL FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,DEV,OUTTOL, , LOADPROBE/20X4X20 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 CYL1 =AUTO/CYLINDER,SHOWALLPARAMS = NO,SHOWHITS = YES THEO/1649.342,390.944,1679.484,0.2499315,-0.9677349,0.0319912,69.13,0 ACTL/1649.342,390.944,1679.484,0.2499315,-0.9677349,0.0319912,69.13,90 TARG/1649.342,390.944,1679.484,0.2499315,-0.9677349,0.0319912 MEAS/CYLINDER HIT/BASIC,1631.237,478.04,1642.32,-0.1269641,0,0.9919073,1631.237,478.04,1642.32 HIT/BASIC,1657.776,485.583,1663.14,-0.8947827,-0.218213,0.3895472,1657.776,485.583,1663.14 HIT/BASIC,1653.388,485.583,1697.425,-0.7678186,-0.218213,-0.6023601,1653.388,485.583,1697.425 HIT/BASIC,1622.46,478.04,1710.89,0.1269641,0,-0.9919073,1622.46,478.04,1710.89 HIT/BASIC,1595.92,470.498,1690.069,0.8947827,0.218213,-0.3895472,1595.92,470.498,1690.069 HIT/BASIC,1600.309,470.498,1655.784,0.7678186,0.218213,0.6023601,1600.309,470.498,1655.784 HIT/BASIC,1607.806,441.466,1656.744,0.7678186,0.218213,0.6023601,1607.806,441.466,1656.744 HIT/BASIC,1603.418,441.466,1691.029,0.8947827,0.218213,-0.3895472,1603.418,441.466,1691.029 HIT/BASIC,1629.958,449.008,1711.85,0.1269641,0,-0.9919073,1629.958,449.008,1711.85 HIT/BASIC,1660.886,456.551,1698.385,-0.7678186,-0.218213,-0.6023601,1660.886,456.551,1698.385 HIT/BASIC,1665.274,456.551,1664.1,-0.8947827,-0.218213,0.3895472,1665.274,456.551,1664.1 HIT/BASIC,1638.735,449.008,1643.279,-0.1269641,0,0.9919073,1638.735,449.008,1643.279 HIT/BASIC,1646.233,419.976,1644.239,-0.1269641,0,0.9919073,1646.233,419.976,1644.239 HIT/BASIC,1672.772,427.519,1665.06,-0.8947827,-0.218213,0.3895472,1672.772,427.519,1665.06 HIT/BASIC,1668.384,427.519,1699.345,-0.7678186,-0.218213,-0.6023601,1668.384,427.519,1699.345 HIT/BASIC,1637.456,419.976,1712.81,0.1269641,0,-0.9919073,1637.456,419.976,1712.81 HIT/BASIC,1610.916,412.434,1691.989,0.8947827,0.218213,-0.3895472,1610.916,412.434,1691.989 HIT/BASIC,1615.304,412.434,1657.704,0.7678186,0.218213,0.6023601,1615.304,412.434,1657.704 ENDMEAS/ $$ NO,Level 1 Cylinder 1 PNT1 =FEAT/POINT,RECT THEO/1631.237,478.04,1642.32,-0.1269641,0,0.9919073 ACTL/1631.237,478.04,1642.32,-0.126964,0,0.9919073 CONSTR/POINT,CAST,CYL1.HIT[1] PNT2 =FEAT/POINT,RECT THEO/1657.776,485.583,1663.14,-0.8947827,-0.218213,0.3895472 ACTL/1657.776,485.583,1663.14,-0.8947827,-0.218213,0.3895473 CONSTR/POINT,CAST,CYL1.HIT[2] PNT3 =FEAT/POINT,RECT THEO/1653.388,485.583,1697.425,-0.7678186,-0.218213,-0.6023601 ACTL/1653.388,485.583,1697.425,-0.7678187,-0.218213,-0.60236 CONSTR/POINT,CAST,CYL1.HIT[3] PNT4 =FEAT/POINT,RECT THEO/1622.46,478.04,1710.89,0.1269641,0,-0.9919073 ACTL/1622.46,478.04,1710.89,0.126964,0,-0.9919073 CONSTR/POINT,CAST,CYL1.HIT[4] PNT5 =FEAT/POINT,RECT THEO/1595.92,470.498,1690.069,0.8947827,0.218213,-0.3895472 ACTL/1595.92,470.498,1690.069,0.8947827,0.218213,-0.3895473 CONSTR/POINT,CAST,CYL1.HIT[5] PNT6 =FEAT/POINT,RECT THEO/1600.309,470.498,1655.784,0.7678186,0.218213,0.6023601 ACTL/1600.309,470.498,1655.784,0.7678187,0.218213,0.60236 CONSTR/POINT,CAST,CYL1.HIT[6] PLN1 =FEAT/PLANE,RECT,TRIANGLE THEO/1626.848,478.04,1676.605,-0.2499315,0.9677349,-0.0319912 ACTL/1626.848,478.04,1676.605,-0.2499315,0.9677349,-0.0319912 CONSTR/PLANE,BF,PNT1,PNT2,PNT3,PNT4,PNT5,PNT6,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/TRANS,XAXIS,CYL1 ALIGNMENT/TRANS,YAXIS,CYL1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/END CIR1 =FEAT/CIRCLE,RECT,OUT,LEAST_SQR THEO/0,0,0,0,0,1,69.13 ACTL/0,0,0,0,0,1,69.13 CONSTR/CIRCLE,BF,PNT1,PNT2,PNT3,PNT4,PNT5,PNT6,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 RECALL/ALIGNMENT,INTERNAL,STARTUP $$ NO,Level 2 Cylinder 1 PNT7 =FEAT/POINT,RECT THEO/1607.806,441.466,1656.744,0.7678186,0.218213,0.6023601 ACTL/1607.806,441.466,1656.744,0.7678187,0.218213,0.60236 CONSTR/POINT,CAST,CYL1.HIT[7] PNT8 =FEAT/POINT,RECT THEO/1603.418,441.466,1691.029,0.8947827,0.218213,-0.3895472 ACTL/1603.418,441.466,1691.029,0.8947827,0.218213,-0.3895473 CONSTR/POINT,CAST,CYL1.HIT[8] PNT9 =FEAT/POINT,RECT THEO/1629.958,449.008,1711.85,0.1269641,0,-0.9919073 ACTL/1629.958,449.008,1711.85,0.126964,0,-0.9919073 CONSTR/POINT,CAST,CYL1.HIT[9] PNT10 =FEAT/POINT,RECT THEO/1660.886,456.551,1698.385,-0.7678186,-0.218213,-0.6023601 ACTL/1660.886,456.551,1698.385,-0.7678187,-0.218213,-0.60236 CONSTR/POINT,CAST,CYL1.HIT[10] PNT11 =FEAT/POINT,RECT THEO/1665.274,456.551,1664.1,-0.8947827,-0.218213,0.3895472 ACTL/1665.274,456.551,1664.1,-0.8947827,-0.218213,0.3895473 CONSTR/POINT,CAST,CYL1.HIT[11] PNT12 =FEAT/POINT,RECT THEO/1638.735,449.008,1643.279,-0.1269641,0,0.9919073 ACTL/1638.735,449.008,1643.279,-0.126964,0,0.9919073 CONSTR/POINT,CAST,CYL1.HIT[12] PLN2 =FEAT/PLANE,RECT,TRIANGLE THEO/1634.346,449.008,1677.565,-0.2499315,0.9677349,-0.0319912 ACTL/1634.346,449.008,1677.565,-0.2499315,0.9677349,-0.0319912 CONSTR/PLANE,BF,PNT7,PNT8,PNT9,PNT10,PNT11,PNT12,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A2 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN2 ALIGNMENT/TRANS,XAXIS,CYL1 ALIGNMENT/TRANS,YAXIS,CYL1 ALIGNMENT/TRANS,ZAXIS,PLN2 ALIGNMENT/END CIR2 =FEAT/CIRCLE,RECT,OUT,LEAST_SQR THEO/0,0,0,0,0,1,69.13 ACTL/0,0,0,0,0,1,69.13 CONSTR/CIRCLE,BF,PNT7,PNT8,PNT9,PNT10,PNT11,PNT12,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 RECALL/ALIGNMENT,INTERNAL,STARTUP $$ NO,Level 3 Cylinder 1 PNT13 =FEAT/POINT,RECT THEO/1646.233,419.976,1644.239,-0.1269641,0,0.9919073 ACTL/1646.233,419.976,1644.239,-0.126964,0,0.9919073 CONSTR/POINT,CAST,CYL1.HIT[13] PNT14 =FEAT/POINT,RECT THEO/1672.772,427.519,1665.06,-0.8947827,-0.218213,0.3895472 ACTL/1672.772,427.519,1665.06,-0.8947827,-0.218213,0.3895473 CONSTR/POINT,CAST,CYL1.HIT[14] PNT15 =FEAT/POINT,RECT THEO/1668.384,427.519,1699.345,-0.7678186,-0.218213,-0.6023601 ACTL/1668.384,427.519,1699.345,-0.7678187,-0.218213,-0.60236 CONSTR/POINT,CAST,CYL1.HIT[15] PNT16 =FEAT/POINT,RECT THEO/1637.456,419.976,1712.81,0.1269641,0,-0.9919073 ACTL/1637.456,419.976,1712.81,0.126964,0,-0.9919073 CONSTR/POINT,CAST,CYL1.HIT[16] PNT17 =FEAT/POINT,RECT THEO/1610.916,412.434,1691.989,0.8947827,0.218213,-0.3895472 ACTL/1610.916,412.434,1691.989,0.8947827,0.218213,-0.3895473 CONSTR/POINT,CAST,CYL1.HIT[17] PNT18 =FEAT/POINT,RECT THEO/1615.304,412.434,1657.704,0.7678186,0.218213,0.6023601 ACTL/1615.304,412.434,1657.704,0.7678187,0.218213,0.60236 CONSTR/POINT,CAST,CYL1.HIT[18] PLN3 =FEAT/PLANE,RECT,TRIANGLE THEO/1641.844,419.976,1678.524,-0.2499315,0.9677349,-0.0319912 ACTL/1641.844,419.976,1678.524,-0.2499315,0.9677349,-0.0319912 CONSTR/PLANE,BF,PNT13,PNT14,PNT15,PNT16,PNT17,PNT18,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A3 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN3 ALIGNMENT/TRANS,XAXIS,CYL1 ALIGNMENT/TRANS,YAXIS,CYL1 ALIGNMENT/TRANS,ZAXIS,PLN3 ALIGNMENT/END CIR3 =FEAT/CIRCLE,RECT,OUT,LEAST_SQR THEO/0,0,0,0,0,1,69.13 ACTL/0,0,0,0,0,1,69.13 CONSTR/CIRCLE,BF,PNT13,PNT14,PNT15,PNT16,PNT17,PNT18,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,UPR=0 RECALL/ALIGNMENT,INTERNAL,STARTUP
