I'm just curious if anyone else finds it troubling that when you inspect a hole using auto-circle, lets say at a depth of .5, PC D-MIS transfers the error to the zero depth along I assume the theoretical hole center-line to give you a deviation that may or may not be correct at that level depending on how good that hole is to the hole vector. I know many might say to use a cylinder, but we have had problems there too because aparently PC D-MIS assumes the hole is normal to the surface it pierces and takes the vector of the cylinder from the surface. Just seems to me if you measure a hole 1/2" down, the measured values should be 1/2" down. I know I can turn show hits on, but that does not get me the center of the hole 1/2" down as approximated by PC D-MIS using it's internal algoithms.
V3.7 MR2 - XP SP2
V3.7 MR2 - XP SP2
