I am about to inspect these parts, but the -B- and -C- datums have me scratching my head.
Is this datum callout legit?
This is odd. Level to A, but what to do with B and C?
Can you get the fixture from manufacturing in which they make this part? See how they hold it. What are the hard points, where are the clamps. Follow what they do in mfg. This may not be right, but in this case I think you are better off to just do what they did.
This is very ambiguous. I have never seen this before.
pretty common callout here in wafer valley
they want the center of the part as your datums B & C
you can do this easily with pcdmis
create a mid-line between the two sides
create a mid-point between the two arcs
this will now be your center
with the mid-line also being your rotation of your alignment
so your alignment would be something like this
level to top surface
rotate to mid-line
topsurface is z zero
mid-line is x zero
mid-point is y zero
good luckLast edited by bob mappes; 01-08-2007, 05:13 PM.Which one gets ridden today? MPH vs MPG..tough choice, both are FUN
Starrett RGDC 4028-24 :alien:
Thanks all.
I went to the engineer, and he agreed with what you all have said. It is tiny though. Looks like it has an appointment with Mr. Sticky Tape. That will be the only option I have and still get to the features.
Bye.** "Well, ain't this place a geographical oddity. Two weeks from everywhere!"~ Ulysses Everett McGill **
try using hot glue to hold it
put a dab on a 1-2-3 block and press it on it while still hot
you want the datum a to be up so you can check most of it from thereWhich one gets ridden today? MPH vs MPG..tough choice, both are FUN
Originally posted by Sl33stak View PostI know this is an old post but it applies to part I just checked. My question is WHY dimension it this way? I'm obviously not an engineer so I can't "think" the way they do.
As a programer, I would probably either, one, sent the print back to them and asked for a updated print, or submitted an Engineering change order, if that's what it is called there, or checked it to the functional/critical features, and marked up a print. Then submitted all the information to them.
I would also check it my marked way, and their way, just to see any differance.
But yeah, i have seen some pretty messed up callouts, and I have to stop and ask the same question, why?
Looks fine to me. The only thing is for datum -C- I would use tangent points on the 2 radii (tangent to datum -B- midline), and use a midpoint of these 2 points as my origin. So level to -A-, rotate to -B-, set origin xy to -C- and z to -A-.sigpic
Global Advantage 12-22-10
TESASTAR M SP25 4.3mr2
It looks legit to me due to the simplicity of the part.
Normally, major machined datum(s) tied to raw material/casting as your starting point(s), in this case almost all of the machined features on this part are used to establish part coordinate.
You can either dimension casting features to the part coordinate or machined features to casting coordinate, the sketch is simple, easy to understand, it’s symmetrical all around and everything is covered, it’s a smart way to dimension it (IMO).
Got a part with a BS GD&T callout.
Imagine if you will, a flat plate. It starts out basically as a rectangle with a small 'bump-out'...-
06-18-2007, 08:51 AM -
Hi, I am fairly new to inspection and print reading, which could be why Datum C on the attached print has me completely stumped me (only part of the...
07-31-2009, 04:02 PM -
Okay, Here is the scenario-- I have complex Datum C: 1 tab is angled x axis = 91.15 degrees and 94.05 degrees in Z axis. The other tab is angled X axis...
06-10-2016, 06:22 PM -
by RDI_VectorOk, so looking at Attachement: Datum A is a no brainer, along with Datum C. However when i look at Datum B, and the requirements called out by other features...
09-27-2008, 08:54 AM -
by cad_man1212After or engineers where left in a room rubbing each other’s foreheads they came up with a new way of detailing drawings. So, the idea is constructing...
02-16-2018, 11:57 AM -
