I have an engine block with different variation in the cylinder bores diameter depending on the part number size. The 2 different normal’s are 4.19 & 4.25...is it possible to hide the measurement of 4.25 and show the 4.19 base off a value measured say between 4.17 and 4.21 of the cylinder bores diameter? And the other way away to show the 4.25 dimension and hide the 4.19 dimension if the value measured is between 4.23 7 4.27...Or is it possible to do it with a part number at the beginning of the program using a if then statement. Thanks for your help.
Kenn
Kenn
