I have a program I've spent the past few days working on, and I'm using CAD and decided to run the program thru offline to see if my Theo values all seemed to still match up tight with my CAD (As I programmed off the same CAD model also). Just a general "correctness" check because I started to question a couple of the nominal results that started coming back from some of my constructed features that I had added recently. Well after running through the program offline I found that the features were not showing up were they should on the CAD model (maybe within 1mm or so). Im not sure what went wacky, I suspect it might have been some time after I added or edited one of my alignments (You know how PCDMIS likes to help you out sometimes
Anyway I seem to remember an option that let you relearn the nominal value for your hits based of the CAD, something similar to "Find Nominals", but how do you get PCDMIS to do this for features that are already created? Find Nominals in the PCDMIS setup options seems to only work during initial creation of the feature.
Thanks
Thanks
