I was wondering where the data is stored pertaining to probe calibrations.
Let's say I calibrate my 4x50mm, if I look at the results from the calibration it is not perfect, but the machine comps for those imperfections correct? Also, where are those comped settings stored?
I ask because after an upgrade I (yes It's my fault) set both our machines search path for the probe files to a common probe folder on the network. After that we started getting not matching results from one machine to the other.
I was wondering if the comped results are stored in the probe file itself? If so, when the probe is calibrated on one machine, then later the other machine calls up that probe, will the second machine be trying to run on a probe that is comped to the first machine?
Does this make sense?
