Taking PH10T off
  • Taking PH10T off
    In order to take the front cover off of my CMM, the PH10T head needs to be taken off first. How would you square the head when putting it back in? I was told this would be ok to do as long as the head is put back in square and you re-calibrate all probes. I've never taken a PH10T off before and could use some help.
    Using a Sheffield Dicovery II (D-12).
    I use A90B90 and A90B-90 and the master ball
    Set head to A90B90
    With tip in the probe, align tip at the back center of the master ball.
    Lock Y axis
    Raise head up
    Rotate head to A90B-90
    Move tip over the back center of the master ball and see how far forward or backward the tip is from the back of the ball.
    Rotate head accordingly but only half the distance.
    Repeat until satisfied.
    Now cal the tips at those angles and compare the values for those angles.
      Set head to A90B90
      Lock Y axis
      Raise head up
      Make sure you use a tip that isn't bent when you do this.
        Set head to A90B90
        Lock Y axis
        Raise head up
        I do it the same way except I use a screwdriver sticking up so I can get it closer before I check with master ball and calibration, It will take a little time, when I get it better than .020 I stick with it, I use a 50mm long tip when I do it.
        B&S Global 544
        Using 3.7mr3
        Peace
        Greg
          Uh... yeah - good point. hehehehe
            One thing that I have seen some customers do with the Discoverys is to take a pair of sheet metal scissors and cut a slot in the cover so that you can remove the cover next time without removing the head. (Just do a good job, if you do!)
              Hi cmmguy,
              I have Sheffield Discovery's II in our shop and have never had to remove the head when taking the covers off. It is a tight opening for the head but it can be slipped over if you are carefull. Move the Z all of the way up to the + stop switch. Remove the cover screws and tip the cover toward the front of the machine. I stand on the table so I can see if any cables get snagged. For head sqareness I have a program that I run to square things but it is written in MeasureMax so it probably won't help.
                Ok now I'm getting 0114 & 0115 errors when calibrating probe tips. Something to do with calibrations. I've squared the head to within .001".
                  Originally posted by Ninja View Post
                  Hi cmmguy,
                  Some you can do that with. The earlier machines you could not. I think that the DIIs were changed to allow it - for obvious reasons.
