On Pc.dmis 3.7 To Re-call A Prgram Do You Use The Equate Alingment Method To Align The Part
Re-call
What do you mean by recall a program? You should have a manual alignment first, this will "tell" the software approximately where the part is on the CMM. Then a DCC alignment. They should both be in the program. You should just click on EXECUTE (the little red exclamation point) and it'll run.When in doubt, post code. A second set of eyes might see something you missed.
You RUN the program, mark all, and execute. You will then measure the alignment features again, it will measure the DCC alignment features, and you will be re-aligned. It will then (if it is all one program) go and measure all your features again.sigpic
Originally posted by John Kingston View PostWhat do you mean by recall a program? You should have a manual alignment first, this will "tell" the software approximately where the part is on the CMM. Then a DCC alignment. They should both be in the program. You should just click on EXECUTE (the little red exclamation point) and it'll run.
Thought I said that....When in doubt, post code. A second set of eyes might see something you missed.
by sscandlonHow do I add a move point so I can execute my program without manually measuring the features fro every part beforehand .
03-27-2019, 04:48 PM -
by J. LuskI am not using CAD....
When I "program", I usually take 3 features and insert an alignment using these, and go into DCC mode.
10-07-2008, 11:06 AM -
by jamshedI have been reading up on the forum to get my information. Most important is never alig without rotate.I rotate in my Rough alignment, do I have to rotate...
01-22-2017, 06:25 PM -
by XANTHOFILEI have a simple program to measure the notch steps in a car key. I do a manual alignment to locate the part in a fixture made using a universal fixturing...
08-20-2014, 03:11 PM -
by AuRulesWant to know if I measure a plane and then 2 circles and create a alignment in manual mode, then start a loop, remeasure the same features and create...
02-23-2007, 12:28 PM -
