I was under the impression that if you were picking the scan points off of a CAD model that it would omit the holes and only stay on the CAD surface that you picked. I currently have a saddle that has a elevated area where wire will be plowed and I tried to perform the scan (Patch, Linear Open, and Linear closed) but it will not stay on the surface that I have highlighted and it does not omit the center hole. I am currently using Version 3.5 MR1 with a microexcel with a MIP head. Any info would be greatly appreciated. Thanks.
Straying scans
I dont believe PCDMIS is collision(or non collision in your case) aware.
I know that this si not true for 3.7 and below..for linear open/closed scans you dont even have to pick the surfaces... I would suggest breaking up the scans and creating a feature set. You might get what you want with section scans, but they are a little mopre involved.sigpic
