q01x40 what is the smellrs hole you can check
  • q01x40 what is the smellrs hole you can check
    i m checking a .06 hole but my retract is go to the other side of hole and then hits like a pinball .
    what can i do.
    I'm going to take a deep breath, close this window, and walk away for a while to save the membership from my inquiries into what a "smellers hole" is.
    In regards to the size thing when I used to do sheetmetal I checked locations on pilots done with a 60 drill (0.400 Nom). Again that was location only.
    Craig
      Craig that is only because you know what a "smellers hole" is, thats what they have on them "pilots"
      B&S Global 544
      Using 3.7mr3
      Peace
      Greg
        Smaller tip.
        Ask sheffield about the retract/ backoff thing
        Slow the CMM down.
        If you do alot of very small features, globally change the move/touch tolerance (machine settings under sheffield)
        Look Here
          Cristian,
          Put your pre-hit and retract numbers to 0. Put your check depth to 0. Use the "find hole option" and you should be good with this setup. After the small holes change your prehit/retract/check distance back to what you had previously.
            Originally posted by JamesMannes View Post
            Cristian,
            If he has a Sheffield he has the backoff to contend with.
              You see, that is what I don't know. That is why I want him to call sheffield and find out definitively if that backoff in the controller is updated when the retract is adjusted. It might be now.
              The other issue - which is not on the B&S machines is the move and touch tolerance in the machine's controllers. I think I saw a setting for that under sheffield in the Settings Editor of PCMDIS
                I can't remember how that works would it be after the feature or after each hit? How about a move distance after the feature?
                  In the controler, and it is after each hit. I am wondering if he is teaching and this is happening when he teaches. I do not know enough about Sheffield to help much other than do what J said.
                  Craig
                    The MovePosTolerance is set to 1mm in the registry. This may have to be tightened up?? But not sure.
                      I have a sheffield. When I change the retract, backoff changes too. I thought they were the same. When taking hits manually when writing a program without cad the retract has to be changed in the setup menu instead of parameter settings menu. You can set the prehit and retract as low as you want in parameter settings, but if you don't change them in the setup, F5, the probe will bounce back and forth in the hole like a pinball.
                      Sheffield Cordax RS-150
                      SMP-350
                      PCDMIS 3.7mr3
                        Craig
                        im sorry smallest
                          sorry smaller ok
                            Cristian,
                            thank you ja mes
                              sorry smaller ok
