I was told at the PCDMIS training that anything under 0.015" STD DEV is ok. Where is everyone's max at? What is a good STD DEV to stay under? 0.015" seems high to me.
Calibration - STD DEV
I would say MM, NOT INCHES ("). Nowayinhell would I accept 0.015" for the STD DEV for ANYTHING. You can basically double that value to get any of the 'shape' items, ROUNDNESS, SPHERE, FLAT, STRAIGHT, etc. (at least, it will be DANG close). So, I guess it depends on WHAT that STD DEV is for? CAlibration results? NO WAY! Alignment features on a fixture? NO WAY! A measured feature of a part, well, that will depend on the tolerance of the part.sigpic
That has to be MM. and that is a little high for MM for simple probes.
Although, how many of their trainers have real world experience?
On a Discovery, 5 microns on a good probe, and up to 17 microns on a bad probe.
Good= within the Renishaw guidelines of module
Bad = Not within the guidelines of the module
Star probe - forget them....
Originally posted by cmmguy View PostStar probe - forget them....
Originally posted by craiger_ny View PostFirst time I've heard anyone else say that. Now I don't feel so bad. I get a big ration here for refusing to use one. everyone whose seen a picture of a CMM sees one of those being used so they think I should use it. There is one guy here that insists I use it instead of tip rotations (he is a Ziess guy). I still refuse. I don't know why that is the most requested thing here in a plant full of people that don't know jack about CMMs. They have their place but that place is not with most of today's hardware and certainly not with most of our tolerances that is for sure.
Craig
Originally posted by cmmguy View Postsure wish i checked sheet metal....
Originally posted by Goodluck View PostI never see anything over .0002 inches so that is my limit. If it comes up .0003, I clean the tip and the calibration sphere and run again. I've never had it come up .0003 after cleaning.sigpic
Originally posted by Matthew D. Hoedeman View PostWhat-you-talking-about, eh? This machine is 20 (or more) years old and yes, I check sheet metal. The machine (factory) specs are +/-0.0007" (linear, repeat, sqaure, etc., and I am still within them) and I use 1/2 of my machine spec as a limit for my calibration STD DEV. What gives? What does sheet metal have to do with that, huh?!
j/k
What is the tightest tolerance on your worst sheet metal part?
by patnaurI am going through calibrating my probe. It is coming up with a STD dev of .002 I have not seen it this high before. I am in millimeters in my program....
03-07-2011, 12:08 PM -
When doing a Qualsphere calibration, what is an acceptable Standard Deviation in Microns? I am accustomed to Imperial units, and Qualsphere deviations...
09-21-2017, 04:39 PM -
by kingsld1We had our CMM calibrated last month and it didn't meet specs. Linear Accuracy was out in all three axes with the Y axis being the worst.
X Spec...-
03-03-2020, 02:50 PM -
by JigneshI can select either mm. Or inch. Box when I make a new program in PCDMIS 2010. Did someone find new method so results would have appeared in report window...
02-14-2016, 01:45 AM -
by calbrittonHow do I change this. My programs are in inches but the probe calibration results are in mm.
08-19-2015, 04:44 PM -
