Step from Pro/E
  • Step from Pro/E
    Hi!
    I have some problen importing step-models from Pro/E.
    A lot of surfaces are missing ,especially chamfers.
    Anyone else having this problem? (3.5mr2)
    I haven't had a problem with Pro/E, but I do have issues with UG created files. I usually have to bring them into Solidworks, and re-export them out as .igs in order to have a usable model. I'm stuck at 3.2063 though.
      I have that problem once in awhile. Seems to depend on our customer and are engineering department and what translation may or may not have happen. I seem to have more luck with IGS. than STP., but I use both. I would try the same thing with IGS and see what happens.
      BS
      Windows 7
      Pc-Dmis 2015
      Global Performance 7-10-7
        Sometimes the feature is not missing it just has a surface laying over the top of the CAD model. Try Delete CAD option in PC-dims, just have the surfaces box ticked and click on the surface of your model near where the missing feature should be and delete. You can always undo if not successful.
        Sometimes the designer forgets to clean up the model.
        Dave
        • Samsdadmatt
          Step Model
          by Samsdadmatt
          Hello you lovely people.
          I have imported a Step file cad model into my program but there are parts of the model missing, is there any way i can...
          06-29-2016, 05:37 AM
        • IZAKK
          type of model
          by IZAKK
          Can someone tell me how i can tell which type of model i imported. I tried a few model i.e. STEP, IGES, etc... but i forgot which one looked and worked...
          10-14-2009, 02:33 PM
        • David Wedel
          Bad Model Surfaces.....
          by David Wedel
          I've imported a model into 2013 mr1 and CAN highlight all surfaces when creating a vector point except the outside oml, it just blinks when I click on...
          04-01-2015, 02:26 PM
        • RClone
          parsing step file
          by RClone
          I was trying to upload a cad file when this box came up "parsing step file" and then the computer locked up.
          I tried several times,...
          07-25-2008, 03:51 PM
        • FAT FREDDY
          cad problems
          by FAT FREDDY
          hey,
          I HAVE A STEP CAD FILE THAT PC-DMIS WONT MARRY INTO. I can open the model using VIS-MOCK(all looks good) but when i try to import into...
          02-07-2007, 09:00 AM
