Auto dimension after each existing feature?
  • Auto dimension after each existing feature?
    Can this be done with a mass edit or such automatic?
    Anyone have an idea??
    Much appreciation to anyone who has a trick.
    Thanks G-man ~ Happy Holidays
    sigpicThanks a Millionth
    Well, once the program is written (all features programmed) you either have to put all the dimensions at the end with one go or you ahve to put a dimension, one at a time, after it's feature. You can, however, put your cursor at the bottom of the program, go to DIMENSION-LOCATION, then place your cursor after each feature as you select it to dimension. You do not have to leave your cursor (and thus the insertation point of the dimension) where it is in the program, but you can not get a feature that is 'lower' in the program than your cursor.
      EDIT-PREFERANCES-SETUP
      Under the dimension tab, check the auto dimension box.
