If your certificate of calibration states that your volumetric accuracy is .0006 inch, do any of you assume that if you only use for example one half the machine volume for your work that your machine is accurate to say .0003 inch?
I am interested in learning if you think your machine is more or less accurate when you use a smaller part of the machine volume than it is when you use the entire volume.
In other words if the manufacturer states one thing for the size of your machine and you only use a proportionally smaller volume for your work, do you think your machine is more or less accurate than the statement on the certificate?
Please let me know what you think and the reasoning behind your statement both for and against.
Thanks!
Hilton
Thanks!
Hilton
