lost probe file
  • lost probe file
    Can't get probe to qualify using 3.7 trying to setup probe file using 2x 20 mmshank will not calibrate shank
    Did you put a check-mark in the qualify shank box?
    You also need to specify a depth at which to qualify the shank.
    Also, try to stay away from using shank tips.
    Last, which version of 3.7 are you using. If possible, upgrade to 3.7mr3.
    Regards,
    ZydecoPete
      all other probe files aer working. the probe file was lost this weekend
      I have created probe files the file i create is not recognized by the programs
      • calbritton
        Probe file
        by calbritton
        Has anyone else had this happen? I created a new program this morning and selected the probe file that I wanted to use. I went into the probe qualification...
        06-14-2007, 09:32 AM
      • Netter
        Probe files
        by Netter
        I have several programs that are using a 1x21mm probe. The technician could not get it to calibrate this morning. It was exceeding the probe diameter...
        02-16-2009, 10:46 AM
      • GomoFazter
        Dedicated Probe Files
        by GomoFazter
        Over time I've accumulated a number of probe builds unique to a given part (and only used for that part). Slot definitions for the tool changer take longer...
        06-02-2016, 11:45 AM
      • fiddlestixx
        Renaming Probe Files
        by fiddlestixx
        When building a new probe file to replace the current probe file (current file is corrupt or otherwise because it won't calibrate at any other wrist angle...
        06-27-2013, 11:14 AM
      • ClayOgre
        stop automatic probe file generation
        by ClayOgre
        I have a number of older programs that haven't been run in a while. Most of them use older probe definitions that are no longer being used. Whenever...
        02-01-2008, 11:13 AM
