Im not specifically sure what you want to do exactly,
However if you are just trying to disable the Dimension in your report you can toggle the Output=none by either selecting the option button using the F9 dialog or by changing the code to none in your program.
What happened was somebody went into my program and did something that gives me POINTDATA information on my inspection report. Under that heading in the report, it gives data on HIT#, MEAS X,Y,Z, VEC I,J,K, AND DEVIATION. I didn't have that in my report before and now I cannot find where to turn it off so it doesn't continue to print as my report has gone from 5 pages to 21 pages. I have looked through my program for possible erroneous REPORT commands that would be telling the program to do that but to no avail...I hope this additional information may help you help me. Thanks
Do you have a line something like this in your program, if yes, put your cursor there and press F9, change what you want.
Hi.
You put cursor in dimension in the Edit window which has point data, press F9. Then look in right bottom of Dimension Dialog, take off the Check mark in Textual box. Hope this help
I have inserted a Powerpoint document into my program providing part setup instructions for the part onto the cmm plate. Since I have inserted this document...
I have a problem where AUTODEV shows up on my reports if printed from inserted code, but if I view and print the report from the report window everything...
