Cristian, I assume that the probe may be running into the part? Double check that the vector is going the correct direction, +1 for up, -1 for down. Also, are you using the clearance planes? If so you may have an incorrect number(- instead of +) set for the workplane you are in?
There are times during the shift where an Emergency Error comes up for no apparent reason. I was taking points for a manual alignment and then I could...
I get error messages every once in awhile after the program runs and it's usually 10-20 windows. After clicking OK there are more. Doesn't do this all...
