Trig using variables
  • Trig using variables
    Can I take assigned IJK values and have the tangent calculated from it. I have looked through the HELP files and it is of NO HELP.
    Here is my code which missing something like how and where do I place the "TAN" statement.
    PLN_RFACE =FEAT/PLANE,RECT,TRIANGLE
    THEO/1.3101,-0.7086,-0.1107,0.9396847,0.0000591,0.3420419
    ACTL/1.3101,-0.7086,-0.1107,0.9396847,0.0000591,0.3420419
    CONSTR/PLANE,BF,RFACE_1,RFACE_2,RFACE_3,,
    OUTLIER_REMOVAL/OFF,3
    FILTER/OFF,WAVELENGTH=0
    ASSIGN/V1 = PLN_RFACE.K/PLN_RFACE.I (where do palce the TAN statement to make this work??)
    Craiger, this should be right up your "alley"
    TIA
    Duane
    Contura Calypso 5.4
    TAN would be of an angle so we need to get the angle. I'm trying to think of the pitfalls of different quadrants and positive verses negative vectors in calculating that. Maybe I'm reading too deep into this.
    I'm giving it some thought but what exactly is the intent?
    Craig
      I wanted to use the resultant angle to create a generic feature relative to that specific angle as I know it will vary from part to part.
      I know I can tolerance the angle between 2 features and assign variables from the dimensions and then construct my generic feature but I thought this might make the program look cleaner and have less garbage in it.
      tanA = side / side (which in essence is the I and K values)
      .342 / .939 = 20°
      Contura Calypso 5.4
        OK your .K is a cosine that represents one angle relative to the origin as is .I is it the angle between these two angles you need? I am slow to catch on sometimes and I guess I'm not following this.
          Ok, so you are trying to calculate the angle of the plane's vector relative to an axis? Why not just dimension this angle and use that as a variable?
            Because I have tunnel vision and don't want to do it any other way
            I was just playing with this and wanted to know if it can be done. I'd rather have a sinlge line of code in my program than have tolerance lines that I don't need showing in my program.
            When I was programming with GeoMeasure I used high level langauge to create features, calculations and the like to make the program "look cleaner".
            Contura Calypso 5.4
              Be careful trying to calculate angles from IJKs. they are compounded when a K vector is introduced....
                I believe you may be looking for:
                ASSIGN/V1 = ATAN(PLN_RFACE.K/PLN_RFACE.I)
                which should work, but I can't seem to get it to produce the correct result in 3.7 MR2.
                  Aren't the angles returned in radians?
                    Yes it is in radians (forgot about that - no wonder it did not look right).
                    ASSIGN/V1 = RAD2DEG(ATAN(PLN_RFACE.K/PLN_RFACE.I)) should work then.
                    Of course it may need to be done in steps.
                      YES!! That works GREAT!
                      Thank you all for your help on this.
                      Contura Calypso 5.4
                        Will you post the corrected version
                        would like to keep in my notes
                        Thank you
                          Here's the code that works for the angle calcation from assigned IJK values.
                          I will also post this in the CODE forum.
                          Thanks again to RussL, cmmguy and craiger.
                          RFACE_1 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
                          THEO/1.2809,-0.4456,-0.0304,0.9397,0,0.342
                          ACTL/1.2809,-0.4456,-0.0304,0.9397,0,0.342
                          TARG/1.2809,-0.4456,-0.0304,0.9397,0,0.342
                          THEO_THICKNESS = 0,RECT,SNAP = YES,$
                          AUTO MOVE = NO,DISTANCE = 1
                          RFACE_2 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
                          THEO/1.2838,-0.8337,-0.0383,0.9397,0,0.342
                          ACTL/1.2838,-0.8337,-0.0383,0.9397,0,0.342
                          TARG/1.2838,-0.8337,-0.0383,0.9397,0,0.342
                          RFACE_3 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
                          THEO/1.3657,-0.8465,-0.2633,0.9397,0,0.342
                          ACTL/1.3657,-0.8465,-0.2633,0.9397,0,0.342
                          TARG/1.3657,-0.8465,-0.2633,0.9397,0,0.342
                          ASSIGN/V2 = RAD2DEG(ATAN(PLN_RFACE.K/PLN_RFACE.I))
                          Contura Calypso 5.4
                            Isn't that only good for a two dimensional angle? In other words, one vector component I, J or K must be zero.
                              Yes, only a 2D angle. That is what I was looking for. I am not sure, but I think that you should not use this (adding the 3rd vector) to try and create a 3D angle. I think that if the correlating angle is needed you should assign another variable.
                              Contura Calypso 5.4
