I got probemih m8 and probetp2 and i wont manual calibrate star i install everythink probetp2 and extend 5way 5times tip4by20 an i calibrate but when i check a circus 315 i heve circus 271 i think i do something wrong. Somebody help my ???
Hi i have problem with star
Re: Im from Poland
mayby but i have in hardware defininition in probe utilities:
1.probemih_m8
2.probetp2
3.exten5way
-tip4by20mm
-tip4by20mm
-tip4by20mm
-tip4by20mm
-tip4by20mm
I used my pcdmis manual. Not like regular :P We dont writte the programs. I dont know how to calibrated good that configuration.
ThanksComment
About 10 of my co-workers were born in Poland. Half of them are amoung the sharpest guys in the business and the other half are good hands. Try measuring the calibration sphere. If my theory is correct you should get a reported size 40 from what the artifact is known to be. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Are you using the same tip for all the hits or are you trying to take one hit with each of the 4 tips for the circle? You must tell the software which of the five tips you are using each time you change tips. So to measure a 4 hit circle with one hit taken on each of the 4 horizontal tips, you must take 4 individual hits, specifiing which tip is taking each hit, and then construct the circle from those hits. If you are using the vertical tip for all hits, then I do not know what is wrong. When you reply to this post to the right of the smilely face you will see a paperclip. It is for attachments. You can upload a screen shot there. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
by Tim HindsmanWe need to be able to use a star probe on a new and exixting parts. We line up the probe per John Kingston's instructions. We calibrate our regular probe...
04-22-2009, 04:07 PM -
by tnguyenHi everybody.
Today, I just buy a M2 Fixed Star probe. I tried to build it. But no luck.
When I set the 5way probe, then I don't...-
03-14-2007, 06:39 PM -
by Dml989All,
This is the first "star probe" I've worked with so far. I built it in the probe utility box. I am unsure if I have built it...-
02-15-2017, 10:26 AM -
by Wes CiscoI have built a star probe using 3mmx10mm tips. I have a dual sphere qualification tool. I am using all 5 tips in the A0B0 position only. I select the...
03-02-2006, 04:59 PM -
by BoomerI think that I might be sol here....... Because my head is rotated at a90 b0 my calibration runs fine, except for some bad deviations....Thinking about...
06-08-2007, 03:45 PM -
