Program crashes when I go to Help
  • Program crashes when I go to Help
    Hello,
    I am having problems with the help files. When I try to access the help when in the program either through the F1 key or through the menu it crashes. I tried to reinstall the software over top the current one and it did not fix the problem. I am using 3.7MR3. Any ideas on how to fix it? I need to find a height on a cone at a specified diameter.
    Thanks,
    Craig
    Originally posted by Craig H View Post
    Hello,
    Thanks,
    Craig
    The answer you seek SHOULD be here:
      Well view this post for the solution to the help issue.
        Too slow, Goodluck! I beat you to the punch.
          Story of my life. Any ideas on how to help with the problem that caused him to go to the help file anyway?
          Note - I edited my post above to reflect your speed.
            I think I have measured ONE (1) Cone in all my time working with Pcdmis. Just no demand for it here. So, I am clueless (which boogerboy will tell you anyway!).
              CONSTRUCT>>CIRCLE>>CONE(radio button)>>DIAMETER. Help file describes it pretty good.
                Help files are working now. Now to find the height.
                Thanks,
                Craig
                  Thanks,
                  Craig
                  Sorry I read you wanted DIAMETER. Same method except insert HEIGHT for DIAMETER.
                  EDIT...
                  Sorry again, If you want to find the height of a circle at a specified diameter then you type in the perfect diameter and then report out the Z value(assuming a Z vectored cone) for that constructed circle.
                    James, that worked.
                    Thanks
