alingment
You will just have to re-measure everything. Of course, you manual alignment, followed by a DCC alignment, should be the first thing you do. Don't ever just use the machine co-ordinates for your alignment.sigpic
WELCOME TO THE FORUM!!!
Please see this post first...
http://pcdmisforum.com/showthread.php?t=3139
Then it depends upon which version you are using. Equate alignment works quite well in some versions and not so well in others. Equate alignment is built almost specifically for the accidental bump of the part and subsequent recovery.sigpic
Originally posted by Matthew D. Hoedeman View PostYou will just have to re-measure everything. Of course, you manual alignment, followed by a DCC alignment, should be the first thing you do. Don't ever just use the machine co-ordinates for your alignment.
hey why is it bad to use machine coords for alignments?
i can think of clearplanes being out of range on our CMM
but whats wrong with doing it?
Well, if you use machine co-ords. for your alignment, then everytime you move the part to a new place on the table, none of your program will be any good, the part would ahve to be in the exact place, every time, and that is impossible. Even if you don't move the part, say it is tied down tight, if you shut off the controller and have to re-home the machine (or re-home for any reason) your machine numbers in relation to where the part is will have changed. The home position will NEVER repeat to the exact same place every time. So, if you have only used machine co-ords, where are you now? An alignment MUST be done on the part, one that can be re-measured for whatever reason and will be the same, every time.sigpic
Alignments can be done to machine coordinates. Even if you home out. Part of your measurement routine will need to accomodate this and you will still need to do a part alignment to dimension and find various features but it can be done. Not prudent but there are ways to do it successfully.
I don't do it.<internet bumper sticker goes here>
Originally posted by craiger_ny View PostAlignments can be done to machine coordinates. Even if you home out. Part of your measurement routine will need to accomodate this and you will still need to do a part alignment to dimension and find various features but it can be done. Not prudent but there are ways to do it successfully.
I don't do it.sigpic
by seppleyI have a part program, i have successfully written it to where i can flip the part, and equate the alignment, all works well, until the next part is ready...
07-24-2014, 10:44 AM -
by 12345V2011 MR1
Customer reported a part we delivered is OOT.
We have a copy of their program.
This part is a ring with multiple concentric...-
06-01-2012, 05:28 PM -
by CookeaI am using 2018 R1. I have a part that has different datums on both sides, some of which can only be reached from one side. From what I've read it seems...
10-30-2018, 08:07 AM -
Hello Everyone,
We have an oversize part that will have to be moved at some point during the inspection as there is not enough travel on...-
09-27-2018, 04:04 PM -
by TestedI thought that the equate alignment needed you to measure and create a originial alignment. Then measure some features that your were going to use in...
01-10-2007, 08:19 AM -
