For some strange reason, I can no longer use the help menu from inside PC-DMIS anymore. I can't click F1 inside a window, I can't run help from the drop down menu at the top. What could cause this? Every time I try and use it it crashes and closes the program.
Cannot use "help" in pc-dmis anymore.. help!
You don't say what version. I am not aware of this problem, but someone else may know of it in relation to a certain version. It sounds like you have some corrupt files. I would recommend after shutting everything down and rebooting, if the problem persists, try reinstalling a fresh copy of pc-dmis. Ver 3.7MR3 is the best to date IMNSHFO. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
help files registry fix
1. backup your registry first
2. export your settings editor file to a safe place
then
Try this...
I had trouble with the help files when "upgrading" from 3.5 to 3.7 something got stepped on in the registry. I have since reverted back to 3.5mr2 for other reasons greater than this.
I hope this helps yaLast edited by Mike N.; 05-17-2007, 10:56 AM.sigpiccall me "Plum Crazy"....but you only go around once!
Originally posted by nkayWAI View PostIt's a bug that occurs when you install Internet Explorer 7.
As a temporary fix, delete the PSAPI.DLL file from the pcdmis directory.
Thanks a lot nkayWAI!!! I know there is also a hotfix for a microsoft service pack that many need too. Would it be possible for such "bugs" and "conflicts" to be posted by B&S/Hexagon/Wilcox somewhere on this forum? This would be a tremendous help to many! TIA
Lookie here--from WILCOX
Don't know if this will help you. Just stumbled across it this morning. Site updated 12/12/2006.http://www.wilcoxassoc.com/support/ie7_fix.htmLast edited by Rick Coleman; 12-13-2006, 09:32 AM.sigpic:eek: Bring out the comfy chair!:eek:
I Installed PCDMIS Ver3.7MR3 today and I'm having a problem. I need to be able to have 3.5MR2 Avaiable if I need it. I backed up all of my files first,...
04-08-2006, 01:17 PM -
by AJHVW93Why is it not recommend to un-install previous versions of the demon. From what I am seeing their not shared files. I usually keep at least one other...
10-10-2008, 10:56 AM -
by SchmidtHi Everyone
Im fairly new to PC-DMIS and therefor need the help function badly, but every time I try to open help, or anything that has...-
04-16-2009, 04:58 AM -
by B. Jacobs
I have had PC-DMIS shut down on me 5-6 today for no reason. I am trying to program a part and just when I think all is good, BOOM, shuts...
04-13-2006, 12:49 PM -
by jroyleIs there a way to move my software to a new workstation? I have a customer that is running 4.2, and the workstation running their software died. I'm...
10-22-2007, 07:14 PM -
