Star probe for SP80
  • Star probe for SP80
    I am using a global image with a sp80 probe head. It does not articulate. I need a star probe with the #2 probe (-1,0,0) rotated 15 degrees about Z so it has a shank vector of -.9659,.2588,0 and probe #4 has a vector of .9625, -.2588,0. Is this possible? I have calibrated over and over but it seems to think the probes are still square.
    Might be a dumb question, but you did go into your probe utilities & add that angle didn'nt you.
      You can not add an angle with a SP80 probe. All probes are 0,0. The shank vectors can be achieved thru star probes. They are all built Square to the axis. I want to rotate the star (about Z )15 degrees. After I calibrate the program still thinks the probe is square. (shank vector 1,0,0)
        Weel, you will have to edit the PROBE.DAT file and for a star probe, that will be quite a task. However, once you have them calibrated, teh relationship between them all wil be correct. And, once they are calibrated (you may have to do it manually the first time) they should update to the actual angles. Calibrate the 'down' tip first, all by itself, with the tool in a known position, then manually calibrate all of them, then do it in DCC, it should calibrate correctly.
          Thanks. For now I am going to move the part 15 degrees each way, and do three seperate programs. It will go faster.
