Iterative Alignemt
  • Jeffrey Lovely
    nothing will happen
    its just letting you know you have a point abouve the .15 tol that you set
    next part may say .19 then .33
    so you get a choice do you want to measure the part if 6 out of the 9 points measured .50
    all points below .15 will not show
    Originally posted by Clay_Man View Post
    pc-dmis 3.7 mr2 cad++
    Good morning all, and thanks in advance for the help.
    I am doing an iterative alignment, using 9 vector points for leveling, 2 surface points for rotation, and a vector point for origin.
    Have set my point target radius at 0.15mm and fixture tol at 0.15mm.,
    after the cmm in dcc does the alignment I get error saying point A3 is off by 0.18mm in the Y.
    So i guess my question is what will happen if I continue on programming,
    or should i open up my point target and fixture tol.??
    Well, you should do a MANUAL iterative alignment first, with 'loose' tolerances followed by a DCC iterative alignment with tight tolerance. You can open up the RADIUS value a little higher (it is the 'side to side' amount of acceptabel error) and possibly tighten up the fixture tolerance (that is the 'up and down' or 'in and out' error, the approave vector error). You best bet would also be to MEASURE ALL ALWAYS on the DCC alignment, it will then actually measure all the points twice. If you still are getting the error after that, then your part is just plain wrong. You will have to find out what is an acceptable amount of error for your datum features.
  • Clay_Man
    started a topic Iterative Alignemt
    Iterative Alignemt
  • S_Cliff
    Iterative Alignment Error
    by S_Cliff
    I'm trying my first iterative alignment and I keep getting an error message that says "Iterative Alignment Error". I'm using A1-A3 to Level,...
    02-03-2021, 08:54 AM
  • JJordan
    iterative alighnments
    by JJordan
    I'm trying to set a iterative alighnment off my cad model. But when I start to measure everything is skewed. My machine axis is inline with my cad axis...
    10-25-2006, 12:01 PM
  • Tony.Hirotec.Aus
    Iterative alignments
    by Tony.Hirotec.Aus
    Hi
    I have an iterative alignment made up of six vector points, the vectors of the three points that perform the level and the vectors of the two...
    10-08-2006, 10:14 PM
  • jonas
    Iterative Alignment
    by jonas
    I am trying to do a 6 pt iterative alignment, I have only had to use this approach a couple of times in the past, I got it to work before, but I am having...
    10-22-2009, 12:56 PM
  • enviro
    Iterative Alignment
    by enviro
    Can anyone give me the rundown on Iterative aligmnment procedure? like where to start and what to expect.
    The main problem I am having is do I...
    03-03-2009, 03:47 PM
