Hi All, I'm back on my CMM after about a year off from programming and I could use a little help. I have a small part that has a seal bead protruding up from the Z plane. It is .080 at the base and is .055 high with 30 degrees per side. How can I create a point at the intesection at the z plane on each side to determine the width at it's base? I tried 2 points on the z plane heading towards the angle and 2 points on the angle heading down towards the z plane but it creates the line horizontal to the z plane.?????
I am using tip 0.5x21MM. (3.5MR2)
Thanks
Thanks
