line between 2 points
  • line between 2 points
    It sounds like such a simple thing. Create a line between 2 intersection points. I have done this hunderds of times using vector points but for some reason PC-DMIS will not create a line between 2 points that were constructed as intersection points between 2 circles. See attached screen shot. Any ideas as to what would cause this. I have tried in V4.0 and 4.1. I have tried casting a new point on top of the intersection points and it still fails. ARGGGH.
    t.
    Global Image 555
    PH10M-TP200
    PC-DMIS Cad ++
    Win7 64 bit
    V2014.1
    Did you try creating a 3D line?
      3d not 2d ?
        yup - same message - 3d or 2d.
        Global Image 555
        PH10M-TP200
        PC-DMIS Cad ++
        Win7 64 bit
        V2014.1
          Maybe 3D line will work.
          PC-DMIS 3.7 mr3
            Also tried in in V3.5MR2 - same type of message for 3D or 2D line.
            Global Image 555
            PH10M-TP200
            PC-DMIS Cad ++
            Win7 64 bit
            V2014.1
              So, you tried creating a cast point on top of each of the other two points? And, you tried creating a 3D line from those two cast points?
              That should work.
              If not, I would suggest shutting down - PC-DMIS and computer - restarting and see if that helps. That is all I've got.
                Maybe try creating a line between two other points. Will it let you do that?
                  Look at the theoretical XYZ values for the constructed points. Both points are at 0,0,0. That's why the line won't construct because theoretically, it is the same point. Use CONSTRUCT CIRCLE instead of GENERIC and try the CAST option to create each circle to the points. You can adjust the diameters in the code afterwards.
                  Stu
                    Stuart, thank you. I didn't notice that. The points looked good in the graphic display. If I try to const a cast circle from the vector point PC-DMIS creates the circle in a plane that is normal to the vector that the vector point was taken at and it won't let me change it. The circles have to be in an x,y plane. Any ideas?
                    t.
                    Global Image 555
                    PH10M-TP200
                    PC-DMIS Cad ++
                    Win7 64 bit
                    V2014.1
                      success
                      Stuart - I was able to get it to work using your method. Thanks much !!! Attached screen shot shows the final code to complete the thread.
                      t.
                      Global Image 555
                      PH10M-TP200
                      PC-DMIS Cad ++
                      Win7 64 bit
                      V2014.1
