Can someone please explain how my perpendicularity is out. Measured top plane and cylinder and it is pependicular to .001 or less (great) measure bottom plane (part is only 1" thick) compare to same cylinder out .0045". Ok check parallel manually between the 2 faces with less then a .001 variation. What is going on here Origin is on the top face and center of cylinder.
Perpedicular issues
Originally posted by bboyd View PostCan someone please explain how my perpendicularity is out. Measured top plane and cylinder and it is pependicular to .001 or less (great) measure bottom plane (part is only 1" thick) compare to same cylinder out .0045". Ok check parallel manually between the 2 faces with less then a .001 variation. What is going on here Origin is on the top face and center of cylinder.
Ok, I have a question or two. Is your cylinder an ID or an OD? Are your planes measured similarly? By that I mean, is one composed of 40 hits over a 5 by 5 area and the other 3 hits over a 1 by 1 area?
Is this a machined part? Is the flatness of each plane very good?
Perp is "view" ie workplane and alignment(rotation) dependent if that has any bearing on the values you are getting.
The cylinder is and ID measurement.
The planes are measured the same amount of hits over approx the same area.
It is a machined part with both faces and hole done at the same time.
Could one or 2 bad hits on the plane affect this that much?"A good design is the one that allows engineers the ability to change gracefully what they forgot to do right the first time!!!"
Originally posted by cmmguy View PostPerp is "view" ie workplane and alignment(rotation) dependent if that has any bearing on the values you are getting.
I did a quick check with a micrometer (not as accurate as an indicator but the area is not that large and I was looking for a quick confirmation) and the 2 planes are parallel to less then .001"A good design is the one that allows engineers the ability to change gracefully what they forgot to do right the first time!!!"
Originally posted by bboyd View PostI did a quick check with a micrometer (not as accurate as an indicator but the area is not that large and I was looking for a quick confirmation) and the 2 planes are parallel to less then .001
Originally posted by Goodluck View PostHow can it be workplane dependent? In order to check the perp. of a cylinder to a plane you would have to rotate the workplane through 360º around the cylinder to get a true 3d perp.
Now, if the circle symbol is present, then ignore what I said earlier - I should have been more clear.
by DCHRMOn the dwg, we need to perpendicular cylinder B to plane A within .012mm
assistant lab manager says the values should be the same if we were...-
03-14-2018, 11:58 PM -
by 12345I want to construct a line, parallel to the C/L of a cylinder
on the OD of the cylinder.
that is the I/O a plane and the cylinder
04-14-2009, 12:45 PM -
by williamI'm wondering if there is a way I can construct and callout a line where a cylinder meets a plane. Just for explanation purposes, imagine you sectioned...
01-27-2015, 08:46 PM -
by Slug DawsonImagine an empty beer mug lying on it's side. However, the handle of the mug doesn't drive straight toward the center of the mug, it's at a slight angle....
02-05-2010, 03:30 PM -
by RayRonanHi,
I'm new to PC Dmis and am a bit confused and confounded which actually is close to my normal state anyways but I'm hoping someone can...-
03-25-2013, 01:13 PM -
