I am using 4.1 with a 1.8 gig processor and 1 gig memory and after the program is finished it takes up to 1min 30 seconds to start printing my report any ideas on how to speed it up or is it time to get new computers?
Slow to respond to printer
I agree with James. Especially if your portlock is on the printer port and not a USB dongle. I had all kinds of trouble printing when the printer was plugged into my portlock and the portlock plugged into the computer. Sometimes it wouldn't print. Sometimes it would delay (like you are seeing). I couldn't run programs while printing. On and on and on. I switched to a USB printer and all those problems are gone.
Do you have your CAD model active during the analyze? I found that for certain large models, the analysis-time can be very high. Just rename your model so PC-DMIS starts the program without it and you will see your processing time go way down.
Solved this problem for me.
by Jonathan SI have always had a problem with printing while PC-DMIS is running. If I send something to the printer, the program will stop running. I can usually click...
04-13-2006, 01:49 PM -
by MWMCKEEPc-dmis is set to "pc-dmis converter 250" for printing. Need to change to put my printer in it's place. It is set as the default printer in...
06-03-2009, 02:04 PM -
V4.2MR1 - My programs usually print the report at the end of execution. Now it's printing 1 sheet that says;
PCL XL error
Error:...-
01-19-2012, 09:51 AM -
by taasncWhat is the best printer that anyone has found that works with PC-DMIS? No issues!
03-07-2017, 06:03 PM -
by dph51I have encountered a recurrent problem with some of my programs. When I have multiple part runs to be measured, I use an input statment at the end of...
10-22-2008, 09:12 PM -
