Serial I/O to USB Adaptor
  • Serial I/O to USB Adaptor
    Does anyone know if you can use Serial I/O to USB adaptors for the CMM and Probe controller connections so that you can connect to the USB ports?
    The reason I ask this, is because newer machines are moving away from the standard I/O ports in favor of USB.
    Also if it is doable, will the standard printer portlock still work or will a USB portlock be needed?
    Any help will be appreciated.
    Brian.
    In regards to the I/O it may depend on your drivers I can't speak much about it to be honest. In regards to the portlock though that would be between you and B&S. There is much perception here as to what that answer should be but I'd bet the only way to find out is to talk to God and see if he has any pull with B&S. They would be the ones that you'd have to work with on "trading" your serial port lock for a USB one. If you have a local/regional guy that sells and or services machines/PCDMIS that would be the first place I'd call. Standard printer portlock should work regardless of how you communicate with the machine controls.
    Craig
      Yes you can if you are using WIN XP and the software that you are using for the serial comm allows you to set a different com port.
      The "printer port lock" uses LPT1 not the serial port. So that should not be a problem
      • Gary Fitzgerald
        Parallel Dongel
        by Gary Fitzgerald
        We have a parallel port (25 pin) port lock and purchased a new computer that does not have a parrallel port only USB. In order to use Pc-dmis we purchased...
        12-31-2008, 05:03 PM
      • Scirocco
        New member
        by Scirocco
        Hi you all.
        Just a short introduction and one or two questions on the board.
        My name is Hans and i am working as a application engineer...
        07-27-2006, 04:46 AM
      • Stewart_57
        Port Lock
        by Stewart_57
        I was wondering if you can switch port lock from machine to machine. The reason I ask is because the port lock with data page + is on a machine that does...
        04-15-2014, 11:50 AM
      • Allen Long
        Slow to respond to printer
        by Allen Long
        I am using 4.1 with a 1.8 gig processor and 1 gig memory and after the program is finished it takes up to 1min 30 seconds to start printing my report...
        12-05-2006, 06:57 PM
      • Snaggy
        Portlock query
        by Snaggy
        Hi all you learned ladies and gentlemen out there in Demonland. We have just got a second user machine which is all hunky dory, however it came with one...
        09-17-2008, 02:54 AM
