How would you qualify a 25 mm disc probe. It is on the standard pull down menu. Would you just touch off on the equator of your qualsphere or try to take a hit on top center as for a regular ball tip ??
thanks in advance
GLOBAL FX 12-15-10
3.7MR3, XP/SP2
Best bet is to tell the machine that your artifact hasn't moved. To do it manually split your hits between each half of the equator but do not touch off the pole.
I have a cylinder tube with ID grooves that I need to probe or scan. After searching the forum, I finally got the disc to run thru the calibration procedure...
Morning we are using PCDMIS 2012. I am having trouble installing a disc probe to our system I have followed the same steps as I have in installing the...
