When you have a fixture/gage for a sheet metal panel, & you align your program to the fixtures tooling balls or corner, how do you set up to measure the holes for true position in relation to the datums on the part? I ask this because usually the datums are either pinned or clamped, so it is hard to measure them proper. With the surface datum features, shold I just measure as close as I can to the clamp?
Also, how fo I go about referencing my hole to a datum when that datum contains more then 1 feature that is on more then one surface (think of an inner car door where the fixture nets are around the seal surface.)?
