I am measuring a sheet metal slot that is on a slight angle to the workplane/body axis. A stud is going thru this hole perpendicular to the workplane/body axis. How can I show the slots diameter as the stud would see it? Because of the angle, the diameter the stud sees is actually smaller then the diameter when measured normal to surface.
Need help measuring a slot diameter...projection issue I think
I am in a discussion with the home office on the methodology for measuring slots. I have found that using the square slot function with find hole turned...
04-02-2008, 07:13 PM -
by Jeff HuntWhat I have is a cross between a round & a square slot. The ends of it have a radius, but that radius does not equal the diameter of the slot. Heres...
04-06-2006, 08:42 AM -
by olivia311I'm currently laying out a part with many relatively narrow slots (2.02 mm x 25.5 mm.) I need to measure the slot minor (diameter) and slot major dimensions...
04-24-2014, 09:49 AM -
by billygwh3I am attempting to find hole "center" for an inside round slot auto feature on .090" thick sheet metal part. I use it all the time for...
12-02-2015, 05:09 PM -
by dfkudlaI'm running 4.0 and am having an issue with checking a square slot stud.The width checks fine but the length is checking to large by approx 4mm.I'm using...
02-24-2011, 02:11 PM -
